That strange weight in the vert's trunk
  • warmseth
    • Jan 2011
    • 313
    #31
    They might not have had the battery in the trunk on US models because of trunk space. Yuppies were often concerned about whether a set of golf clubs would fit in the trunk and perhaps with the reduced capacity of the vert trunk and a battery, there just wasn't room for the precious sticks.
    90 325is
    85 RZ350
    75 RD350
    7? RD400 race bike
    • Nsquared97
      • 1656
      #32
      Originally posted by CrusherCurtis
      How the hell could I have missed this. This is my second vert! I feel ashamed. Does it really weigh 70 lbs?
      Not that much haha. But it is pretty heavy. When I was tearing apart my parts car and came across it I was seriously confused.
      • MAXELHOFF
        • Jan 2008
        • 414
        #33
        no top
        It gets worse. From memory, there is a carpeted, pressed steel plate bolted over the weight. Lots of space under the weight...for water.:crazy: BMW logo cast into weight. See last image.
        grain of salt:p
        http://https://youtu.be/H8gOAzYchAE:ot:
        • Vivek
          attention whore/retard/bitch
          • 6167
          #34
          ^But when water gets in, it all rusts away and weight is no longer an issue!!
          But seriously I never knew about this, so the right side of the trunk? I'll take mine out this weekend.
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • TobyB
            • 5218
            #35
            F1 did this a few years ago- what, the 'mass damper?' Renault got told it was verboten...
            Racecar Engineering did a bit on the math- it was actually pretty fantastic.
            That said, I pulled a 30 lb chunk of rubber- suspended steel out of the back of a Nissan
            convertible something- or- other a couple of years back... it made a good... doorstop.
            t
            • Raxe
              • 5346
              #36
              Seriously though, BMW isn't retarded. It's there for a reason. If you want to pull everything out because race car go ahead, but much like the trunk tar, it serves a legitimate purpose.
              • e30shmobberr
                • 1934
                #37
                exactly just like how the spare tire well is shifted to the right and the battery is in the trunk on the right to help off set the weight of the driver.
                Patrick - IG:niicknac
                RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                • Dozyproductions
                  • Jan 2007
                  • 4682
                  #38
                  So what about all the people removing their harmonic balancers from the driveshaft? It's useless as well right?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    #39
                    Pretty sure the spare tire well is shifted to allow room for the muffler...
                    • Bearmw
                      • 1323
                      #40
                      Removed my weight a while ago and used the top sheet metal piece as the base for the approximately 29lb. battery that is now located there. Used a coupe battery cable and snaked the cable through the vert. That cable was just barely long enough and I had to move it around several times to get the correct fit. Put some protective grommets on holes the cable passed through and also had to put some extra protective sheath on the cable in a couple spots to prevent it from chafing on the body. Drilled a hole in the body and used a bolt epoxied on to secure the ground cable to. To secure the battery on to the sheet metal base plate I made some extra hole in the plate and am using some large (like 36") heavy duty zip ties until I come up with a cleaner method. Where the battery was now sits my coil and a small washer reservoir.
                      Like every thing on these cars I think the original purpose of the weight was a compromise; in this case to keep the super discerning sophisticted luxury consumer happy that their car had ultimate smoothness and a feel of solidity but maybe at the expense of all out performance.
                      • MAXELHOFF
                        • Jan 2008
                        • 414
                        #41
                        flexi-vert
                        Cool. Yes, the right side. Let us know if you notice any more cowl shake or vibrations, please.
                        grain of salt:p
                        • Just Scott
                          • Dec 2010
                          • 140
                          #42
                          I recycled mine right after buying the car. Weight doesn't make sense to me. Generally 5-10 lbs = 1 hp.
                          Might consider going on a diet too.
                          1990 325is - sterling silver, very nice, maybe for sale
                          • devon.818
                            • Feb 2011
                            • 2937
                            #43
                            dude, you notice tons of fucking cowl shake! been paying attention the last few weeks. worth it? fuck no!
                            • Raxe
                              • 5346
                              #44
                              Yeah man but think of how much faster the car is now! ;)
                              • GT BMW E30
                                • Nov 2008
                                • 2491
                                #45
                                i removed mine 3 years ago. My parents used it in their car for more traction in the winter. I do not like the shake but have dealt with it. I noticed mine in the trunk cause I saw that my vert looked lower on that corner. There is an issue of water gather there.
                                Quote:
                                Yeah man but think of how much faster the car is now! ;-)
