When I turn the heater fan on it makes horrible noises.
  • e30BMart
    • Feb 2011
    • 658
    A huge rattling sound is made when I turn on the heater fan. What could it be and how do I fix it? thanks!
  • Quadrajet
    • Jul 2008
    • 1278
    It could be one of the blades on the squirrel cage has broken loose from the wheel and it's rubbing on the housing.
    • Nsquared97
      • 1656
      • Click
        • 637
        Yeah my fan buzzes in a fashion that I would think a blade has come partially undone. Turning my fan on speed 2 or higher makes it go away. Making a right turn makes it louder as well.
        ส็็็็็็็็็็็็็็็็็็็็็็็็็
        I need you to exfoliate my ballsack
        Build Thread?
        • mikeedler
          • 6707
          just changed out my fan motor last week, there was nothing left of the bushings! Made the same noises as yours.
          • accident
            • 7303
            I had one half of the blower fan explode in to pieces once. Unbalanced the whole assembly, made horrible noises when the fan was on. I thought my motor was fucked when it first happened and shut the car down. I didn't figure out that it was the fan until I turned the key on to restart it and the noise started again immediately after I turned it on, before I even started it.
            ^ Cool story bro.
            Moral of this story?
            • Raxe
              • 5346
              Need a new blower motor assembly.
              • e30BMart
                • Feb 2011
                • 658
                I can't find a writeup for removing m42 blower fans. Every site I look at doesn't look at all like what I have. (1991 318is) No ac if that changes anything
                • e30BMart
                  • Feb 2011
                  • 658
                  I took the blower motor out and oiled it up. The bushings are finished so it still makes noise.. Probably gonna break someday Ill need to change it.
                  • Click
                    • 637
                    What are the bushings like on these motors? Would it be possible to turn some new ones on a lathe and repair it? I see they are like $300+ new.
                    Build Thread?
                    • kts
                      • Jun 2010
                      • 753
                      Just go to the junkyard and pull one from a car there. That's what I did, cost me $13 and works great so far. If it craps out on me I'll just go pick up another one from the yard.
                        • 34839
                        it's not the bushings that cause the noise (I think you mean brushes). it's the bearings, and unless you have the equipment to balance it at the 10,000+ rpm the fan spins at full speed, you can't replace them yourself.
                        • e30BMart
                          • Feb 2011
                          • 658
                          yeah the bearings... i'll proly go to the junkyard someday... 13 bucks is a great deal :P
