Deadlock big problem Help!
  • e30BMart
    • Feb 2011
    • 658
    So yesterday i got home and locked my driver door as usual (locking all other doors) but instead of just normal locking them it went to deadlock. No big deal you might say, but now the driver door lock is not working... It's turning in butter. So I can't unlock from anywhere else since its in deadlock and can't unlock from driver door cause its fucked. How do i break into my car?
  • Dj Buttchug
    • Jun 2010
    • 7638
    wedge and air pump.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • e30BMart
      • Feb 2011
      • 658
      what do you mean?
      PS:
      Driver lock:
      -turns in any which way with no friction just spring back feeling.
      -makes a slight locking noise when turned to lock position
      -makes no action or noise when turning to unock
      Passenger lock:
      -Can't turn to unlock or lock but moves a mm each way (hens me thinking it's in deadlock
      -the mm it does move toward unlock position moves the lock pin up a bit.
      Trunk lock
      -never worked to unlock itself or any other, just feels like its in deadlock full time. Only works to push open trunk.
      I think the problem is the driver door lock only, not the central locking, is it possible to just change the driver door lock and not the others? will the key be the same?..
      Still need to get the door open though ....
      Any help is appreciated thanks!
      • StereoInstaller1
        GAS
        • 22679
        IF you truly have deadbolt engaged you really are up shit creek.
        No paddle, either.
        You are going to have to take your doorpanel off with the door closed, get inside the door (again, with the door closed) and physically unlock it...because even if you had the window open you still can't unlock it.
        What car is this on? Most coupes and sedans don't have deadbolt, it is a thing for the 'verts, primarily. Some did, but it was not as common.
        Either way, if I had to get in my 100% locked up car, I would pull the windshield. Since you will not be pushing from the inside, you may have to cut the seal, but a windshield seal replacement is not that much money...but you will also likely break your windshield getting it out (since you cannot push from the inside) but seems like most E30s have a pitted to hell windshield anyway.
        For your sake, I really do hope you are wrong about the high security lockout.
        Sorry, man, that really sucks.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • e30BMart
          • Feb 2011
          • 658
          1991 318is.. I'm sure it has deadlock... I'm not sure if it's engaged.. Shit fuck
          • Julien
            • 7471
            No paddle, either.
            Luke
            I like this idea, but use a big suction cup (get it at an auto parts store, body work section) to pull windshield out
            -remove push in plastic trim around windshield, lube up the gasket and start pulling on it with suction cup until it clears the gasket, slowly work your away around
            -get in car, open window
            -remove drivers side seat
            -remove door panel
            -unlock car
            unless there some bypass I'm not aware of..
            Build Threads:
            • e30BMart
              • Feb 2011
              • 658
              I don't know how he did it but my dad unlocked the driver door while I was posting on here and now I can lock/unlock from the pass side so deadlock either was not activated or my dad deactivated it somehow. But if it wasn't why did the pass side lock act like it was jammed by deadlock.. Weird stuff. Dad saves the day, again. :P. Thank you guys for your ideas and help, I appreciate it!
              Mart
              • Julien
                • 7471
                good save, buy your dad a beer
                Build Threads:
                • Regnar75
                  • Sep 2011
                  • 483
                  ^ agree
                  • e30BMart
                    • Feb 2011
                    • 658
                    done. :)
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      Makes me glad I don't have central locking on my 318is...
                      Project M42 Turbo
                      • Stanley Rockafella
                        • Aug 2011
                        • 4056
                        Luke
                        Deadbolt on both my current 88 325is as well as previous 86 325es?
                        maybe just a canadian thing to keep polar bears out?
                        • mr ilia
                          • May 2011
                          • 582
                          I have a deadlock on the 1991 318i, never use it though.
                          • dogsbark26
                            • Nov 2008
                            • 533
                            OP - you really need to fix your locks before this happens again! What if something happens (G-d forbid) to your dad?
                            I'd at least rebuild that driver lock cylinder. Check out the trunk lock too because it should operate all the locks.
                            • Isostar13
                              • Nov 2011
                              • 288
                              My 88 325ix has a deadbolt. I hope OPs situation never happens to me. Glad you got it worked out.
                              1988 325ix
