F30 M3 testing
    F30 M3 testing
    Read its gonna be a turbo 6:
    I'm not convinced that it's going to a be turbo inline six though.
    ส็็็็็็็็็็็็็็็็็็็็็็็็็
    I need you to exfoliate my ballsack
    Build Thread?
      I've also read the BMW recently patented designs for a new V6 :-(.
        Well it dose sound like a 6, and there is little chance that BMW will go from 310kw in the E92 M3 back to around 260kw N/A 6. So I would probably put $10 that it will be a turbo 6.
        I will also put down $5 that it will be a 3lt turbo 6 with 330kw. I come to this conclusion using the F10 M5 as a base. That engine dose 13.2kw/1000rpm/L apply that to a 3lt 6 with 8rpm redline and you get about 330kw.
          Sounds like a turbo 6 for sure.
          M Coupe
            If its based on the m5 motor, then V6 makes more sense. I hope not though.
              I not saying it is based on the M5 motor but if the M5 is putting down 13.2kw/1000rpm/lt then a strait 6 turbo would be very similar in the power department.
              If it is a V6 turbo with out all of this valvetronic bullshit I would slap a motec ECU on that bitch and drop her into the E30. Awesome weight distribution and power.
                Here's a link to that v6 article:
                  A V6 does have some packaging advantages over an inline, so there might be some serious benefit to going that direction.
                  "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
                    no for the v6!
                    Patrick - IG:niicknac
                    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                      Nice looking M5 errr M4?
                        Except v6s can sound awesome http://www.youtube.com/watch?v=JnelyYtGK30
                          nissan makes a nice v6, but wouldn't seem right in a BMW.
                            Nor do turbos but it is the way it is now.
                              Who cares if it is a v6? Obviously their engineers see some advantage to going that route (likely inboard turbos). They will choose the route that ends in better engine performance... if that means it's a V6, then bring it on.
