Since the two sensors are the same, I thought I'd first swap them just to see if one was bad. I also swapped the connectors. Now it won't start at all. I returned everything to the original position, and it still won't start.
New Owner needs help restoring E30
You may have damaged senor connectors that were on their way out...Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
Maybe. One plug just slipped right out of the socket. There is a 1988 528E at the pic n pull. Will that car have the sensors? Seems like it would based on:
from 9/85 12 14 1 710 668
find these on
325e
528eComment
They should be the same sensors, but they aren't that expensive to replace. The rear diff (it it's a 3.25 LSD) out of that 5er would be a nice upgrade for you as well.Comment
I found 2 sensors off an 87 325. Installed them and the car fired right up. I didn't even have to crank it. Normally it would start after 2-3 seconds. This time it was immediate! I drove it around and around, well past the time it would die. Kept going.
Unfortunately I had a fuel leak in my fuel pressure regulator. Started a little fire. No damage, but I need to get a new hood liner.Comment
There you go. CPS's are a huge culprit alot of the time. If the wire splits off from the sensor, just get a new one, BC the old one is done.Yours truly,
Rich
