New Owner needs help restoring E30
  • mrgraphics
    • 221
    Hello - I've now owned my 1986 325es for a little under a month. I've fixed almost everything that was wrong with it, except I have one nagging problem. Hopefully someone here can point me in the right direction to get this girl back on the road.
    Car will start and run fine every time when cold, but as soon as it hits operating temperature (temp needle about half way) it stalls and won't start until it is cold again. There is no fan fare, it just stops abruptly.
    What I've done so far:
    Replaced fuel pump and filter
    Replaced ECU
    Replaced coolant temp sensor
    Replaced coil
    Replaced relays
    Replaced fuses
    Replaced spark plugs
    Diagnostics when it stalls out and won't start:
    Verified I still have fuel pressure
    Verified that I still have 12V+ going to the coil on key ignition
    Any ideas? Thanks in advance.
  • AndrewBird
    The Mad Scientist
    • 11892
    Possibly a bad cold start valve sticking open? #7 seen here:
    http://www.realoem.com/bmw/showparts...59&hg=11&fg=40
    Try unplugging it when warm and see if it runs.
    • mikeedler
      • 6707
      fuel pump? the motor part of the pump might be overheating and then stopping. I had a E21 that did that too.
      • AirplaneBuilder
        • 823
        simple, get a 24v
        oh and welcome to R3V!
        1989 Zinno 325i S50 ZF320
        • mrgraphics
          • 221
          NitroRustlerDriver, I tried that before but after it had already died. Once it dies it won't start. I'll try it again running and see if it still dies.
          mikeedler, I've already replaced the fuel pump. Plus when it dies, I still have plenty of fuel.
          AirplaneBuilder, what's a 24v? I'm somewhat mechanical, but by no means a mechanic.
          • blunttech
            • 12850
            test Crank position sensor
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
            • Roysneon
              • 4505
              W24v is a 24 valve DOHC engine found in E36s, E46, etc. It is a popular swap to perform on E30s for a more modern, powerful powerplant.
              I don't think that's really what you are looking for, however. Welcome to r3vlimited and good luck with the diagnostics.
              Originally posted by mbonanni
              I am a pursit now.
              • mrgraphics
                • 221
                Would the crank position sensor stall the engine when it's already running? I could see how it would stop it from starting.
                • blunttech
                  • 12850
                  Yes it would
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • mrgraphics
                    • 221
                    OK - I'll give it a shot. I've read where even if the ohms test ok, the sensor may be going bad. So I'll have to swing by the Pick-n-Pull.
                    Any e30 crankshaft position sensor will work right? Mine has two since it's an es, so do I scavenge two sensors from two different cars?
                    • blunttech
                      • 12850
                      Edit note I's are diff
                      they are both the same so you need 2 if you are replacing both
                      from 9/85 12 14 1 710 668
                      find these on
                      325e
                      528e
                      M5
                      thru 8/85 12 14 1 708 618
                      find these on
                      325e
                      528e thru 11/86
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • mrgraphics
                        • 221
                        I don't mean to be dense, but I cannot for the life of me locate the sensors. I just can't see them, and the bentley's black and white pictures are so poor that the image makes no sense to me.
                        • bernzpeed
                          • 3917
                          welcome!
                          89 E30 S52
                          Transaction Feedback.
                          • blunttech
                            • 12850
                            they are on the bell housing.. 2 right next to each other.. Jack the car up and get under there.. Youll see them
                            sales@blunttech.com
                            www.blunttech.com
                            Like us on Facebook
                            • lurenz
                              • 2
                              I would say fuel pump relay or key ignition troubles, but I see you already checked on...
