oh boy blower motor
  • Bryan///
    • Nov 2011
    • 290
    oh boy blower motor
    I didnt think that i would have to disassemble the entire dashboard to take out the hvac, but it looks like i do.. Is there any good write ups for replacing the motor its self? because the dashboard has a good write up but im clueless after that.
    '01 e46 330ci blk/blk (GF stole from me)
    '90 e30 325i Traded
    '95 e34 540i/manual swap (electric fire)
    '96 miata M-edition (not quite an e30 so i got below car)
    '93 Audi Urs-4 (like the e34 but still not an e30)
    :hitler:
  • slammin.e28
    שמע ישראל
    • 12054
    Blower motor? Access it from the engine bay.
    • audiquattrot
      • May 2008
      • 3836
      yeah access panel on the firewall. Unclip, and pop out. Should take you no more than 10-20mins tops.
      www.instagram.com/snwmble
      #snwmble
      Current:
      '05 BMW M3 - Silver Grey/Imola Red
      '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
      '15 Mini Countryman - Blazing Red/Carbon Black
      Past:
      '01 Audi Allroad - Light Silver/Platinum Saber Black
      '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
      '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
      '90 BMW 325i - Schwarz/Tan sport *Sold*
      '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
      • DrJosh
        • 2011
        Originally posted by Sonny
        I am a meme for our community.
        • kts
          • Jun 2010
          • 753
          +1 to what everyone above me has said. it's a surprisingly quick and easy job via the engine bay.
          • devon.818
            • Feb 2011
            • 2937
            I have same problem, it doesn't look like there is much room between blower motor and intake manifold. Idk I'll be doing this tonight or tomorrow, yay not
            • kts
              • Jun 2010
              • 753
              it's a bit of a squeeze but really not bad. i removed it from the passenger side and it came out with some maneuvering while removing it easily.
              • Bryan///
                • Nov 2011
                • 290
                wow, fml...at least i didnt go all the way through with it yet and had to replace the gears in my cluster any way, as well as take the ecu out for a chip im going to buy..
                '90 e30 325i Traded
                :hitler:
                • slammin.e28
                  שמע ישראל
                  • 12054
                  BE careful not to bust up the hamster cages when installing the new one, especially if said new one is used.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Can't wait until I have to do blower motor or wiper motor maintenance on my car with the 24v, there is no fucking room there.
                    '89 Alpine S52 with goodies
                    • Bryan///
                      • Nov 2011
                      • 290
                      yep def not too hard.. thanks everyone for the heads up and useful link.. then unit i bought was brand new..or re-manufactured idk if the make brand new anymore.. and for everyone else who commented on here about to do the motor unit..the driver side hamster cage is a tight fit between the top of the engine bay and the intake manifold, but if aligned just right there is enough room to push it through and only bend the driver side hamster cage just slightly with out causing damage...idk if there is another smart person angle to find but it worked fine with me..however im not even sure if it works because i still have half my dash apart and no dme in the car. lets just pretend it works fine.
                      '90 e30 325i Traded
                      :hitler:
                      • Kvasi
                        • Apr 2011
                        • 1122
                        And remember there are 2 different fans before u order a new one. If the "housing" is made of plastic its the widest fan, and if steel its the other one.
                        And thats if u dont got AC..
                        • long tall eta
                          • Jul 2010
                          • 1536
                          you might want to replace the resistor as long as you have her unbuttoned. it's a 30 dollar part that is a common failure. if your fan only works on high, thats the culpret.
                          • Jon325i
                            • 6934
                            This is exactly this issue I ran into a couple years ago. Initially, I thought the fan motor had gone bad but I did a test on the resistor first as a precaution. Turns out the resistor was the problem. I decided to go ahead and replace the fan itself since I had the metal kind and it made some noise during operation.
                            It's a little tricky gaining access at first, but once you're in the job is rather straight forward.
                            Jon
                            Rides...
                            1991 325i - sold :(
                            2004 2WD Frontier King Cab
                            RIP #17 Jules Bianchi
                            • brutus87
                              • 6280
                              this.
                              Make sure you center it too.
