Self locking nuts oval top vs nylon.
  • Massimo
    • Jan 2008
    • 3207
    So the M12 self locking nut that gose on the bolt that connects the trailing arm to the subframe, somehow got loose and came off. Fortunatly the blot did not slip out. Now it is a bit hard to get the original self locking nuts at the moment, the ones with the oval tops.
    I have found some nylon self locking nuts that fit I was think of using them and some loctite. Anybody have and issues with these kind of nuts or are they just as good.
  • FredK
    • 14762
    Nylon self locking nuts will work fine in this application.
    • Massimo
      • Jan 2008
      • 3207
      Thanks for the quick response dude. Do you know a website that with a run down on self locking nuts, with the differences and what to use where?
      • FredK
        • 14762
        Generally, nylon self locking nuts work fine everywhere a distorted-thread metal locknut will, except for higher temperature applications or liquid environments that will attack the nylon.
        I would honestly rather use the genuine BMW locknuts in this application, as they are made in Germany, in a quality-controlled environment, and are probably high-strength (Grade 8.8+). Hardware store alternatives are not always as well spec'd.
        • der affe
          Technical
          • Dec 2005
          • 8452
          True^
          Btw they are called stover nuts
