What's the general concensus on oil additives?
  • Turf1600
    • 9815
    I'm looking for something that will help clean my motor internally. So far the best suggestion I have is to add a half quart or so of ATF and run it for a while. Any other thoughts?
    • 37834
    ATF is definitely a good suggestion. Another option is running Seafoam in your oil as well.
    Grover Beach, California
    BimmerHeads.com
    • slaterd
      • Jul 2011
      • 1731
      seafoam works great when you do the gas tank application, vacuum induction, and directly in the crank case. Just make sure after 100 or so miles you change your oil or else you might get some catastrophic failures. Chances are 1/1000000000 but it's still there. I've heard it'll break up clumps of nasty oil and clog one of the passages and BOOM! But I highly recommend seafoam.
      Originally posted by Wh33lhop
      This is r3v. Check your vaginal sand at the door.
      • KenC
        King of Kegstands
        • 14396
        Run a whole quart of ATF for a thousand miles or so. It has tons of detergents.
        Originally posted by Gruelius
        • slammin.e28
          שמע ישראל
          • 12054
          This.
          This. Ever seen the inside of an auto trans? Clean clean clean.
          • slaterd
            • Jul 2011
            • 1731
            I'll also back up on the ATF. That stuff is made with magic. Any power equipment like air jacks, air hammer, etc we had at the shop that stopped working, we dunked them in a bath of ATF. Next day that shit was sparkly clean and ran so smooth and like new.
            • scottinAZ
              • Dec 2009
              • 1312
              ATF, cheapest, safest and still the best....
              I saved 15% on my Bimmer parts by switching to ...
              • Threehz
                • 1480
                All good suggestions and atf is a classic solution, just be sure to change out any of these additives quickly, the atf you can let slide longer but things like seafoam I wouldn't leave in for long at all, the directions advise the proper time.
                Different strokes for different folks.
                • Nick_S
                  • Apr 2011
                  • 3658
                  I have never heard of using ATF before, I'll have to try that before my next oil change. On my last oil change I ran a quart of Lucas oil stabilizer. It worked great in my Cherokee so I figured worth a shot.
                  91 318is M50 swapped
                  05 Honda Pilot
                  24V swap thread
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    Lucas oil stabilizer is not for cleaning the internals, it is an oil thickener.
                    The OP is asking about cleaning the internals.
