Interchangeable ECU's?
  • =======Live Fast!
    • Nov 2011
    • 248
    Does anyone have any experience successfully running different versions of the Motronic ECU in their cars? I've read "yes" some places and "no" others. My ECU ends with 380 and has a yellow sticker. Being that the mechanic is pretty sure mine is fried I might be in the market for one and didnt know if theyre interchangeable. Thanks!
    sigpic2000 323ci
    1987 325is super etta
    1988 M5
    2000 M5
    1989 944 turbo
    1989 325is
  • =======Live Fast!
    • Nov 2011
    • 248
    Bump. I'm surprised no one has messed with this...
    sigpic2000 323ci
    1988 M5
    2000 M5
    1989 944 turbo
    1989 325is
      • 34839
      Any motronic 1.1 or 1.3 ecu will work - 153, 173, 380, 525, etc..
      • =======Live Fast!
        • Nov 2011
        • 248
        Cool. So you've personally done this or know someone that has?
        sigpic2000 323ci
        1988 M5
        2000 M5
        1989 944 turbo
        1989 325is
        • SoopaGhetto
          • 573
          never personally experienced but from researching, 153 is motronic 1.1 and has more hardware (dual pcb). also has some internal issues with hardware; another common issue which most report is idle.
          1.3 is a good firmware revision and has better hardware (only one pcb) the others (380, 525 etc) are further revisions but are interchangeable; all are motronic 1.3. If you swap, most have good results with 173 and not sure on the later
          becareful of the 154 (i think) as its revised motronic 1.0 running "super eta" setup. the injectors are low impedance so would explode if put into a b25 setup. believe the connectors are the same as the 55 pin which runs motronic 1.1 and 1.3 so it WILL plug right in...
          been a while so i could be wrong on some things.
            • 34839
            154 is still 1.1, not 1.0
            The hardware on all 1.1 are the same, same with 1.3. Firmware differences are minor. Theyre both 55 pin and have the same pinout.
            • =======Live Fast!
              • Nov 2011
              • 248
              My damn ECU is good! ARRRRRGH... Let the wire tracing begin.
              sigpic2000 323ci
              1988 M5
              2000 M5
              1989 944 turbo
              1989 325is
