Can all the pedals just be even?
  • bastianshaw
    • Jan 2007
    • 2210
    I want my brake and clutch even with my gas pedal can this be done?
    im 6'3'' and need more leg room
    can anyone post pics of lower pedals?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    I'm 6'9", I understand.
    • Dj Buttchug
      • Jun 2010
      • 7688
      yea i wish this as well
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Teaguer
        • Sep 2004
        • 6167
        Lurch FTL. :D
        • noid
          • 1537
          Get an after market pedal assembly.
          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
          Your resource to tools and tips: www.rtstools.com
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            I was hoping to find out what changes in footwell space are made with the boosterless setup Jean and Jgood and Garey have been talking about, no info on that was given yet though.
            • noid
              • 1537
              Send me your email, and ill send you the PDF, of what it takes to install with that guys bracket. Using dual .625 MC bore for the brakes with 6.25:1 ratio pedals, you should have a daily-able setup.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                But how much room is the question. I also think having the brake pedal pad moved closer to the clutch will help me stop reving the engine when I press the brake.
                • devon.818
                  • Feb 2011
                  • 2937
                  cut and weld?/////////////////////////////////////////
                  • noid
                    • 1537
                    The PDF shows what modifications need to be made to the firewall. Alternatively you could get a three pedal aftermarket assembly. That way all three pedals will be of equal distance.
                    • Wschnitz
                      • 8089
                      ARe they just to close together or are the pedals too close to you, ie legs in dash. If its just too close make bigger seat brakets so you can slide farther back.
                      willschnitz
                      • Varinn
                        • 780
                        Moving the seat back only works to a point. Straight arming the wheel is bad for control, I'm 6'3" and sit with my arms at a decent bend for control, just makes getting in/out harder, and the pedals are real close
                        1990 332i, 4 door
                        2008 KTM 990 Superduke
                        2018 Golf R, 6spd manual (Pending delivery)
                        2017 Mazda CX-5 GT
                        2007 Z4M Coupe - Sold to very nice people
                        • bastianshaw
                          • Jan 2007
                          • 2210
                          Im talking about stock guys, can you adjust them close?
                          • HR2L
                            • 724
                            Unfortunately no. :(
                            • Emre
                              • Sep 2007
                              • 1228
                              You don't want all pedals to be flush. You need the accelerator to be slightly lower than the brake pedal for proper heel-and-toe downshifts. The brake and throttle should be level when the brake is depressed.
                              1987 Mercedes 190E 2.3-16: Vintage Racer
                              2010 BMW (E90) 335xi sedan: Grocery Getter
