What happened?
  • iam
    • 42
    What happened?
    My car has suddenly started to let go of the back when i'm taking left turns. I can catch it so long as i'm doing less than 20 - 30 but I spun out recently at about 45. I have no issues at all when taking right hand turns at any speed.
    I haven't investigated fully but does anyone have any ideas what might be causing such behaviour.
    Hmmm, curious.
    Cheers
    Iam
  • TimKninja
    • 2131
    Tires?
    Differential?
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • kway
      • 1084
      The shitbox Bronzit 318 I used to have used to do the same thing. I once semi-looped it on an offramp in Boston, not even pushing it hard. I didn't put it into the wall, but came to a dead stop sideways across the ramp, and it was the type with concrete barriers on both sides so I was blocking the whole thing.
      As I'm trying to get turned around, I see the headlights of the next car on its way down illuminating the walls. I see it coming around the bend (out my side window) and as luck would have it, it's a Crown Vic moving at a pretty good clip. He stopped in time, but I think we both shat equally.
      Anyhow, I attributed it to rear subframe bushings that were completely blown out. Paired with Eibachs/Bilsteins and 325i rear sway bar made for a tail-happy little fucker.
      Edit: in my case it was mainly right hand turns, but to be honest I scrapped the car before I ever figured anything out.
      '84 318i - Lapisblau/Schwarz (in cryosleep)
      '06 330i - Titansilber/Schwarz
      • Roysneon
        • 4505
        Rear bushings/alignment.
        Originally posted by mbonanni
        I am a pursit now.
        • TobyB
          • 5296
          flat tire.
          t
            If the tires aren't worn out, the likely cause of this is worn trailing arm bushings or bent trailing arms. Possibly aggravated by worn subframe bushing. A four wheel alignment check will tell for sure if there are errors in the rear wheel alignment. Any toe out or a thrust angle will make the car prone to oversteer.
