How often do you adjust your valves?
  • woodisgood
    • 1087
    Be honest. Every time I do I think I should do it more often.....I am at about twice a year.
  • KenC
    King of Kegstands
    • 14396
    That's plenty for a DD M20
    Originally posted by Gruelius
    • rThor432
      • Feb 2007
      • 3907
      Twice a year is overkill, it's not an old aircooled VW engine. I'd say every 10-15k if I had an M20.
      • stamar
        • Apr 2011
        • 1362
        Ive only had the car 15k miles now so I guess its due.
        • Killacortes
          • 1937
          I was paranoid when I had my m20 I adjusted it like 4 times in the 9 months I owned it lol
          r3v does not fuck around. First you get banned, then they shoot you
          • BlackbirdM3
            • 2772
            I adjust mine when they need it. I check them every 4 months or so, or on the track car, before an event.
            Will
            '88 BMW M3
            • bastianshaw
              • Jan 2007
              • 2210
              What's worse case scenario if I've slacked off for 2 years
              • SkiFree
                • Jun 2011
                • 2766
                And the cam would probably be pretty pitted.
                That's worst case.
                ADAMS Autosport
                • bastianshaw
                  • Jan 2007
                  • 2210
                  anyone got a link to that tool jlevie was talking about like feeler guage w a spring?
                  I need to get in gear
                  • rThor432
                    • Feb 2007
                    • 3907
                    ^^You can use a bent coat hanger. The spring style [factory] tool is nice, but not necessary. Bent coat hanger, 10mm, .010" feeler gauge (45 degree blades are nice for this), flat-blade screwdriver (for the hose clamp), and 5-10 minutes are all you need.
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      whats the factory tool for? and is it a good idea to go tighter like .009 and? .008m on intake since ive neglected it for awhile? to account for the additional wear
                      • TehPilot
                        • Mar 2012
                        • 207
                        It only takes 15 minutes to adjust your valves?^
                        Nick
                        Why have American muscle when you can get some German blow?
                        instagram - tehcapo
                        • nrubenstein
                          • 3148
                          No, you're accounting for wear by adjusting the valves.
                          That said, I would adjust at the cam. .006-.007 at the cam works nicely (clearance is tighter due to the rocker ratio - actual clearance at the stem is exactly the same as .010 at the valve). IMHO, adjusting at the cam is a) easier, and b) is less likely to run into accuracy issues from uneven wear on the valve stem.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • bastianshaw
                            • Jan 2007
                            • 2210
                            maybe the second time;)
                            • rThor432
                              • Feb 2007
                              • 3907
                              It is for moving the eccentric adjuster. I always adjust my valves tighter than factory spec. Lots of guys do it in an attempt to quiet the motor down a bit more. The smoothest and quietest BMW single cam I've ever worked on was an M10 in a '74 2002-- I couldn't fit a .006" feeler blade between the eccentric and valve stem. Not saying that I'd do that (I wouldn't..) but I guess that's how far some people go.
