How often do you adjust your valves?
    • 34827
    Originally posted by SkiFree
    And the cam would probably be pretty pitted.
    That's worst case.
    what? No.
    that looks like a case of high miles and/or improper lube. you aren't going to wear out the rocker pad because your valves are a little out of adjustment.
    what's more likely to happen is you'll simply stress the rocker more. more stress = more likely to break.
    I haven't adjusted mine in a while. I probably should. I've been feeling pretty apathetic towards my M20 lately. :p
    • slammin.e28
      שמע ישראל
      • 12054
      Never.
      Hydraulic lifters FTW.
      (Never drive the e28 enough to warrant adjusting any, any time soon.)
      • Mr. Burns
        • Aug 2011
        • 3516
        Originally posted by TehPilot
        It only takes 15 minutes to adjust your valves?^
        on what planet?
        Originally posted by flyboyx
        i have watched my dog lick himself off a few times
        • slammin.e28
          שמע ישראל
          • 12054
          Originally posted by Mr. Burns
          on what planet?
          Mine take <2 seconds to adjust. :rofl: :rofl:
            I adjust valves every 10k (every other oil change).
            • SkiFree
              • Jun 2011
              • 2766
              Originally posted by nando
              what? No.
              While you're right that this particular case is probably a case of improper lube, Bastian was asking for a worst case-scenario (not a "little out of adjustment" as you put it). You will get more excessive wear if the rocker is wildly out of adjustment, but again you're also right to say that in all likely-hood you'll end up with a broken rocker.
              ADAMS Autosport
              • mikeedler
                • 6707
                Originally posted by rThor432
                The smoothest and quietest BMW single cam I've ever worked on was an M10 in a '74 2002-- I couldn't fit a .006" feeler blade between the eccentric and valve stem. Not saying that I'd do that (I wouldn't..) but I guess that's how far some people go.
                and when the motor was warm, I bet it ran like crap and lost a a lot of power. too tight is worst than too loose.
                I do mine when I first buy the car and then never again, usually only have em for a year or so.
                • TehPilot
                  • Mar 2012
                  • 207
                  on what planet?
                  I thought he was implying that.
                  Nick
                  Why have American muscle when you can get some German blow?
                  instagram - tehcapo
                  • rThor432
                    • Feb 2007
                    • 3907
                    It was actually smooth warm, which really suprised me. Didn't notice a lack of power because it was a stock single carb car.
                    Adjusting valves takes 15 minutes or less if you are serious. It will be more if you have a beer between crank revolutions.
                    • Massimo
                      • Jan 2008
                      • 3207
                      Never M42 FTW
                      • Kershaw
                        • 11822
                        never.
                        rotary.
                        .. ftl.
                        i really hope my tester is broken and i seriously dont have a rotor face with 11 psi. :(
                        AWD > RWD
