Anyone use Rotella T diesel oil in their gasoline e30?
  • noid
    • 1535
    A major amount of guys in the atv honda trx450r forum use Rotella T diesel oil instead of running synthetic gasoline oil. Alot of the motors are extremely high strung and receive frequent disassembly; all the engine builders on there swear by it.
    Considering TRX450R engines are flat tappet engines just like an E30, I think it could benefit from the nice amount of zddp, and phosphorus that hasnt been disallowed from being used in diesel oils like it has in gasoline oils by the EPA.
    Anyone use it?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • Vspec
    • Jan 2005
    • 114
    Have you owned or currently own an SV650? Those guys swear by that stuff.
    01/88 325is re-assembly required - Garage recluse - Parts pile growing
    • Jparkr
      HR Admin
      • Jan 2006
      • 3494
      I've never used it, but the rumors i've heard is diesel oil is high in zinc and therefor similar to the oil that was available to our E30's in the 80's/early 90's.
      No personal experience though.
      1987 PRO-3 car /1990 325is (2.7i Concours)
      • Jand3rson
        • 37587
        I was told by quite a few people in a recent inquiry that Shell Rotella T is the way to go, for the reason Parker said, it's good oil, and it's also dirt-cheap. A gallon is $12 at Wal-Mart.
        • turge
          • 2576
          Anyone use it?
          Would running the stuff affect smog at all for ur car? All I know is that I wouldn't try it in California if it did.
          • noid
            • 1535
            ZDDP and Phosphorous are both considered low level cat contaminators. However, 1. It only applies if your consuming oil 2. Current warnings say it 'could' shorten the life of the cat rather then a certainty 3. In the 80's gasoline oil had high amounts of both before the EPA got at it and e30's back then ran just fine with cats.
            • mrsleeve
              • Mar 2005
              • 16386
              Higher levels of ZDDP can be found in Valvoline VR1 raceing oil.
              Or the mobile 1 Racing oils.
              As a general rule the CJ-4 oils for turbo diesels will be higher in ZDDP than gasser counterparts. These include Delvac 1300 and Delvac 1 from mobile, Rotella from shell, Delo 400 from Chevron is all good stuff, and will be great in a m20.
              In my e30 I ran VR1 20-50 in My Duramax I run Delvac 1 (full syn). I used to know ZDDP numbers off the top of my head, and if IRRC the VR1 is 1450ppm and the Delvac1 is pushing 1700ppm. I may be mistaken but those are the numbers I am remembering.
              Originally posted by Fusion
              William Pitt-
              • Holland
                • Nov 2008
                • 7212
                I run the stuff, have been, and more than likely will be for quite some time.
                Originally posted by DEV0 E30
                • quikveedb2
                  • Sep 2007
                  • 2258
                  Just bought some for my next oil change, from what I've read it works well.
                  You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
                  • noid
                    • 1535
                    http://www.joegibbsracingoil.com/ has oil with ~2400ppm but at $17-19/quart is well out of budget for most folks.
                    I think the great thing about rotella T more then anything is that its $12 per gallon.
                    • flyboyx
                      • 8371
                      i actually run the full synthetic rotella t in everything i own including my diesel f350 and my bimmers. even my lawn equipment and my kubota tractor. this oil is awesome and you can't beat the price. about 20.00/gal at walmart. i have been telling people for years how great it is. people are now starting to listen. i recommend you use it.
                      Gigitty Gigitty!!!!
                      • rThor432
                        • Feb 2007
                        • 3907
                        I ran Rotella T (15w40, if I remember right..) in all of my past M20's. They all ran great. Don't know how much the oil had to do with it, but I wouldn't run anything else in an old single cam. It's got a solid reputation and the price is great.
                          VR1 is a slightly better choice than Rotella T, because of a bit more ZDDP. There is no advantage to using synthetic oil in an M20 engine since the oil change intervals need to remain at the factory specification. That interval needs to remain the same to prevent build up of combustion blowby condensates in the oil. I.E., you can't take advantage of the longer life of synthetic oil.
                          An even better oil in an M20 than either of those is Brad Penn 20w50. But it is much harder to find than VR1 or Rotella T. For more than you ever wanted to know about oil (or filters) wade through what is available at http://bobistheoilguy.com
                          • stamar
                            • Apr 2011
                            • 1362
                            what about just any brand of diesel oil, like oreilly brand or napa brand?
                            is it only rotella or delo?
                            • whterice
                              • Jan 2009
                              • 258
                              I ran 15w40 in my previous m20. never ran into a problem and actually had less consumption then when I ran royal purple 15w40.
