Failed NJ inspection again. Ideas?
  • rturbo 930
    • Dec 2005
    • 2629
    Hey guys,
    I've got an '88 325is that won't pass inspection. It has a rough idle when it's hot, but off idle, it runs well.
    Here's a list of things we've checked, fixed or replaced:
    Injectors
    Carbon deposits on intake valves
    Compression test: I don't recall the exact results, but it was something like 145, 150, 160, 160, 150, 145, from piston 1 to piston 6.
    O2 sensor
    Cat
    Checked for closed loop
    Intake manifold hoses
    New spark plugs
    Checked for vacuum leaks
    Water temp sensor
    Checked ingition with a scope
    Checked the valve adjustment
    Might be more I'm forgetting.
    The results (cat was plenty hot):
    HC ppm @ idle:
    Max: 220
    Reading: 1110
    That's the only part it failed. Ideas?
  • flyboyx
    • 8371
    holy shit! thats bad! i just took my ix down for the test it came back with a hc reading of 26. i didn't even know it was possible for yours to be that high. maybe the new o2 sensor is bad? thats where i would start. this is the feedback sensor that tells the ecu how to set the timing and mixture.
    Gigitty Gigitty!!!!
    • Joe G
      • 2947
      find a shop that will inspect another car and hook you up with a pass for a $20 hand shake.
      Current Car: 2011 BMW 135i, M-Sport, 6 speed
      Originally posted by lambo
      Sounds like you need a massage.
      Originally posted by kpeng
      Who the hell is Vlad?
      • bowtie2bimmer
        • 830
        ^ i like that idea
        idle control valve? clogged charcoal canister? install fresh air injection?
        1987 BMW 325ic - Emma
        • JeremyE30autox
          • Dec 2010
          • 404
          Leave NJ?
          Dare 2 Dream Motorsports
          • TurboJake
            • 3780
            Originally posted by rturbo 930
            HC ppm @ idle:
            Max: 220
            Reading: 1110
            WOW!
            Checked the fuel pressure lately? High HC's generally are the result of a rich mixture. Carbon deposits second that.
            I would also venture to say your cat is toast/useless now. All that raw fuel coming out probably torched it.
            Leave Me Transaction Feedback
            • lolcantturn
              • 4588
              High HC at idle on an M20 is directly correlated to the TPS and nothing else. Change that and you will pass definitely.
              Originally posted by TSI
              OEM+
              • rturbo 930
                • Dec 2005
                • 2629
                When we installed the new sensor, it didn't really make a difference. I think the old one was fine, but we tried it just to try it, since we were running out of ideas, and it was pretty cheap. I'll double check it to be sure.
                Originally posted by bowtie2bimmer
                ^ i like that idea
                I'll check these things. Thanks.
                Originally posted by JeremyE30autox
                Leave NJ?
                I like this idea.
                Originally posted by TurboJake
                WOW!
                I'll check the fuel pressure. I know it's running lean.. or is it rich? I don't know, my dad is doing most of the work here since he knows what he's doing. But I think he told me it was running lean.
                We replaced the cat this week. The old one was toast for sure - the high idle readings the first time were just barely passing (212), but today it read around 110.
                I'll look into this as well.
                Thanks guys.
                • lolcantturn
                  • 4588
                  Change your TPS before anything else. I guarantee that's it- Passing at high idle and failing at idle is directly the TPS.
                  OEM+
                  • TurboJake
                    • 3780
                    This makes sense.
                    High HC is the hydrocarbon, raw fuel, coming out.
                    If the TPS is bad, the DME could be thinking that the throttle is depressed, and is constantly dumping load fuel in. Which does, and sometimes doesn't, affect the driveability/idle.
                    Lean mixtures causes high NOx
                    • lolcantturn
                      • 4588
                      This makes sense.
                      This is exactly what is happening. If you search into my M20 days threads, you can see a lot more information into it, but that's not necessary. Change your TPS and not only will you pass inspection, your idle will improve pretty dramatically.
                      OEM+
                        The engine having a rough idle means that it is misfiring, which will dump raw fuel into the exhaust and cause misfires. The cause of the misfires is what needs to be found.
                        The first things I'd do would be to check the rail fuel pressure and have a smoke test run on the intake. I realize you have looked at ignition with a scope, but if more than five years old I'd replace the ignition wires, distributor cap, and rotor. I don't know what plugs you used, but if not the correct Bosch or NGK plug, replace them. Check the idle switch in the TPS and make sure that it is working, by checking for continuity at the DME connector.
                        Were the replacement injectors new or rebuilt parts? If not send your old injectors to RC Engineering, have them rebuilt, and install those.
                        • long tall eta
                          • Jul 2010
                          • 1536
                          is the car chipped? and would that have anything to do with it?
                          • cunninglinguist
                            • Mar 2004
                            • 281
                            LOL I can no longer tell if people are stupid on this site or just trolls.
                            • Thizzelle
                              • 4422
                              check ICV, Injectors, air flow sensor (make sure plate isn't binding inside) also check coolant temp sensor (there's 2 brown goes to your gauge, blue goes to DME)
                              "I wanna see da boat movie"
                              "I got a tree on my house"
