Soda blasters? Who's got one?
  • blocke
    • 1305
    Thinking of picking up a $99 harbor freight special for various little projects. Anyone use these? How big of a compressor do you use?
    Parts Wanted
    The Never-ending Resto Mod
  • blunttech
    • 12850
    I have a big blast cab. I cant imagine the soda blasters demand is much different. I have a 60 gallon upright but cant remember the specs on it. Bottom line is any blaster consumes air like rsully goes through weed.
    My compressor runs almost non stop when Im blasting
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
      I have an Eastwood soda/media/sand/bead pressure blaster. Minimum air consumption is 10cfm@90psi. I drive it with an industrial 5hp compressor rated for 18cfm@100psi and the compressor runs almost continuously. Which is okay because the compressor is rated for 100% duty cycle. Most non-industrial compressors are rated for at most 50% duty cycle. With one of those you can blast for, say, 10 minutes and then you have to let compressor & motor cool down for at least an equal amount of time
      • A.J.
        • 95
        I run a harbor freight soda blaster off of a 2hp/33 gallon compressor. It supplies plenty of air but the soda blaster clogs up every 10-15 minutes and the pickup tube needs to be blown out to clear it. Unless you live in a very dry place, be prepared to deal with it clogging up. Otherwise, it works well for stripping paint and rust.
        • hfabricius
          • 608
          I have this same problem with my Harbor Freight one. I bet a nice filter and water separator would work good paired with the one that is already on the blaster. I can go about 15 minutes or so before it clogs from condensation.
          http://halden-fabricius.tumblr.com/
          • glucklich21
            • 1912
            I bought the $99 ones for my cabby build to clean up the S50 I bought.
            Parts before:
            Parts after:
            Engine started like this:
            Engine after:
            Best $80 (20% off coupon) I ever spent. More before and afters in my thread: http://www.r3vlimited.com/board/showthread.php?t=201703
            • einstein57
              • Jun 2007
              • 10780
              I have a HF cabinet with a 30 gallon husky. It can not keep up with the demand of the cabinet at all.
              www.gecoils.com
              • Gregs///M
                • Mar 2012
                • 2459
                I've done some research about this topic and specifically the HF soda and sand blasters. From what I've gathered, the soda blasters and pressurized sand blasters require a large, high output air compressor. However, I've heard the grey hopper sand blaster works quite well with normal medium size (home mechanic) air compressors.
                I am referring to this unit:
                http://www.harborfreight.com/portabl...kit-37025.html
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
