M3x?
    • 34839
    Originally posted by Ryan Stewart
    The alignment would have to be perfect though. Even the slightest vibration would be catastrophic, trying to shake open the oilpan.
    yes you would have to get the alignment of the front driveshafts pretty close. I don't think that vibration would be an issue, however having the axels at a wierd angle wouldn't be good for their longevity, esp. if you have 250+hp.
    also, all AWD bimmers have the front driveshaft going through the oil pan.. something about a lower center of gravity and equal length halfshafts contributed to that decision.
    • george graves
      • 20003
      Here are some non-m3's running IX drive lines with different motor swaps (euro s50, m30, ect...)
      Dam germans will do anything under the sun.
      It looks as if all you really need is a custom oil pan that the half shafts go thru. A neat idea if you wanted to have a e30 m3 as your winter snow car/mountian climber. But then again....why????
      Originally posted by Matt-B
      • Rob
        • 8166
        that's what tacoma's are for.
        BEERTECH
        • george graves
          • 20003
          I'd rock any of these two!!!!!!!
          • Q5Quint
            • Jan 2005
            • 725
            If you think about all the normal things involved in swapping in a different engine, I think the oil pan and a tranny that mates to the transfercase are the only 2 extra things you have to worry about.
            butttttt I say awd turbo is kind of fun, none of that pansy wheel spinning stuff that 2wd cars do right? It's bragging rights to be faster on a dirt road than most cars are on the pavement.
            • Rob
              • 8166
              Dont forget the front suspension pieces necessary to have axles running through them....
              BEERTECH
                • 34839
                you can use the ix getrag 260, and a swap would have nothing to do with your front suspension (other than maybe stiffer springs for the extra ~50lbs).
                • CleanAzzE30z
                  • Jan 2004
                  • 11794
                  The E30 ix has a friggin shaft running through the oilpan, that is why you dont see M50 swaps.
                  There is probably an M bodied IX someplace but that is hardly a M3x. Buy an S4 if you want a 3800lb M3.
                  Thank you. Well said.
