Schrick camshafts passing Cali smog?
  • =======Live Fast!
    • Nov 2011
    • 248
    Again...not concerned with the visual inspection just smog...anyone passing SMOG with the 288?
    sigpic2000 323ci
    1987 325is super etta
    1988 M5
    2000 M5
    1989 944 turbo
    1989 325is
    • =======Live Fast!
      • Nov 2011
      • 248
      Well went ahead and got the 284...port and polishing everything too. This thing should be pretty tits when I get it back!
      sigpic2000 323ci
      1988 M5
      2000 M5
      1989 944 turbo
      1989 325is
      • Cabriolet
        • 9620
        that will pass smog if your cat is very good. make sure no air leaks and good O2 also.
        Much wow
        I hate 4 doors
        • =======Live Fast!
          • Nov 2011
          • 248
          Man this thing pulls in the high end! I definitely sacrificed some low end with the 284.
          sigpic2000 323ci
          1988 M5
          2000 M5
          1989 944 turbo
          1989 325is
            • 34839
            if your m20 is otherwise stock - you need a higher HR to really take advantage of that cam. that's part of why you lost some bottom end, the dynamic CR with 8:8:1 is too low.
            • =======Live Fast!
              • Nov 2011
              • 248
              HR? Explain please?
              sigpic2000 323ci
              1988 M5
              2000 M5
              1989 944 turbo
              1989 325is
              • camshaftgsxr
                • Aug 2011
                • 416
                HR? Explain please?
                i think he means CR as in compression ratio, probably a simple keyboard error.
                BroWorks.com Bro is a lifestyle
                • =======Live Fast!
                  • Nov 2011
                  • 248
                  So were talking shaving the head and block to up the ratio? Again forgive my ignorance, but how do you boost the compression ratio in these things?
                  sigpic2000 323ci
                  1988 M5
                  2000 M5
                  1989 944 turbo
                  1989 325is
                    • 34839
                    Lol, typing on a slow smartphone sucks :)
                      • 34839
                      You need new pistons, shaving the head and block introduce other consequences that arent desireable.
                      • bowtie2bimmer
                        • 830
                        I love Florida... no inspections :)
                        1987 BMW 325ic - Emma
                        • camshaftgsxr
                          • Aug 2011
                          • 416
                          what other consequences?
                          • =======Live Fast!
                            • Nov 2011
                            • 248
                            Yea. Im curious as well. I know plenty of folks that race in Spec E30 that take the head and block down to the absolute minimum required in the rules. I havent heard about any problems theyve had as a result of it...
                            sigpic2000 323ci
                            1988 M5
                            2000 M5
                            1989 944 turbo
                            1989 325is
                            • der affe
                              Technical
                              • Dec 2005
                              • 8452
                              Timing changes
                              • Wild Ride
                                • Apr 2008
                                • 739
                                I have gone down this road over the past two years:
                                Im at 10.2:1 with a decked head and a 288 and a 2.7l diesel crank b27 rods and b25 pistons double overbore. As long as you don't have headers and intake you will pass the visual. The distance between the cam and crank timing gears will change when you take material off the head. You will need an adjustable timing gear to fix your timing or the car will run like s**t. You will absolutely need a very good tune that is optimized for your setup like a miller war chip megasquirt etc. Don't adjust your fueling with a adjustable fuel pressure regulator it is just a band aid for a proper tune. A good tune optimized for your setup coupled with a good cat will pass smog. It will idle very lopey at 1100 rpm which will spook many smog guys so make sure yours is very lax or ignorant.
                                All together you are looking at 2k plus to create a perfect setup between cam, injectors, tuning, cam gear, wideband, machine work etc.
