friends 98 v6 malibu has no spark.
  • Kozworth
    • May 2011
    • 1339
    New plugs, wires, coilpacks, no spark.
    I was wondering if anyone had a diagram of the power flow from cranking? Like the relays/sensors/fuses that the voltage goes through before getting to the coils?
    I'm wondering if its a bad cks or cas (if it has one), maybe a main relay, etc. Plus, I need to know which wires go to the coils, because the ones behind the ignition coils seem to have been touched (some black tape, maybe prespliced? Seemed like they were toggather though).
    Just trying to help him out and couldn't find any wiring diagrams
  • mrsleeve
    • Mar 2005
    • 16386
    Cps
    Originally posted by Fusion
    William Pitt-
    • Bimmerista
      • Nov 2005
      • 5425
      Those cars had a problem with the theft-deterrent killing the power to the engine at unusual times. Have you confirmed that its not the factory kill switch?
      • bowtie2bimmer
        • 830
        Grounds the coil i believe... I concur, check for a kill switch fault. If not, CPS is another good option. Also cap and rotor
        1987 BMW 325ic - Emma
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Coil Module?
          • Kozworth
            • May 2011
            • 1339
            There is no cap and rotor, its electronic ignition..
            I am very unfimiliar w/ the car, is there more info on this killswitch?
            • mrsleeve
              • Mar 2005
              • 16386
              Yeah prolly not that its not that common
              Coil pack grounds could be an issue as well
              William Pitt-
              • SpecM
                • Oct 2005
                • 4531
                do you have injector pulse?
                if yes, I'd lean twards ignition module
                if no, I'd say CPS or your Passlock anti-theft is screwy
                1989 cirrisblau-metallic 325i
                • mrsleeve
                  • Mar 2005
                  • 16386
                  IIRC ignition module creates a no fuel situation which would be your injector pulse IIRC that is
                  William Pitt-
                  • Kozworth
                    • May 2011
                    • 1339
                    Replaced crank sensor I have no spark. Double checked firing order and its good.
                    How and where would I bypass the anti theft system?
                    Fuel pump relay clicks multiple times like once every few seconds with key on accessory.
                    • TurboJake
                      • 3780
                      9 times out of 10 on the Chevy 3.1, 3.4, and 3.8, A lack of spark is thanks to either the anti-theft system or the ignition control module itself.
                      Take off all the coils, take that bastard off, and take it into an advanced auto parts to get it tested.
                      Leave Me Transaction Feedback
                      • Kozworth
                        • May 2011
                        • 1339
                        The ignition control module is new.
                        If the antitheft was being a pain, would it allow crank but no start? My experience w/ alarms is they wouldn't even allow the car to crank. If so, how would I test this system/bypass
