Running an m20 on E85
  • 5Toes
    • 9836
    Anybody here done it?
    I understand you need larger injectors..? but why?
    Engine temps are cooler I understand, and I am guessing one would want to replace all the rubber fuel lines if taking this seriously.
    Lets discuss it!
    EDIT: quick reading reveals that any rubber component in fuel system should be upgraded to alcohol friendly parts.
    Also the ideal AFR with e85 is much lower, thus the bigger injectors (more fuel with same amount of air)
  • nrubenstein
    • 3148
    Lets discuss it!
    Basically, there is no reason to do it unless you are going turbo. All it gives you is shitty mileage and the warm feeling that you're giving money to one of the most overly subsidized industries in America.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • 5Toes
      • 9836
      It is 105 octane or so, so that means you can run around with higher engine compression without knocking...??
      • Massimo
        • Jan 2008
        • 3207
        It is better for the enviroment.
        Seriously though the only reason to use it is for more hp, because you can run more advance. Word of advice though, buy it by the barrel with good QC, word has it pump E85 can variy wildly with its RON rating.
        • priapism
          • 1182
          It can and will corrode fuel fittings with continued use
          -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
          • TobyB
            • 5298
            It has a lower specific energy, so you have to squirt more of it in for an equal bang.
            I'd build an electric E30 first. But that's me.
            t
            • 5Toes
              • 9836
              Well I guess that the larger injectors are needed because the ideal AFR is much lower, and the same amount of air is coming in.
              • der affe
                Technical
                • Dec 2005
                • 8452
                It is bigger molecules than gas, another reason to you need the bigger injectors to flow more fuel.
                Your mileage will suffer also as it is not as efficent of a burn compaired to gas.
                • asuj158
                  • Nov 2008
                  • 1206
                  Do it, give you a reason to go turbo :D
                  • 5Toes
                    • 9836
                    So, in a nutshell
                    Higher octane, but if I ran my m20 on a dyno with pump gas, then with e85... e85 dyno will be worse power?
                    • der affe
                      Technical
                      • Dec 2005
                      • 8452
                      Yes, without super high compression, lots of timing or boost, you will make less hp. Also, e85 can't be found everywhere.
                      • 325ix
                        • Aug 2009
                        • 7783
                        E85 is available around us at a few stations. It is also a little cheaper, pretty popular with the Subaru crowd.
                          To do this you'd need to replace all the fuel system components with E85 compatible parts, switch to bigger injectors, and replace the DME with a MegaSquirt or other stand alone engine management computer. Or you might be able to get an acceptable tune with a war chip. But timing and fuel maps need to be quite different than what the stock DME has.
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            Just go to a station who has e85, fill up, run it for a week, and report back with butt dyno findings.
                            Don't make this harder than it has to be.
                            • Xat1cZ
                              • 2020
                              E85 costs 0.99 cents / liter vs. ~1.60€ for 95E10 and ~1.70€ for 98E5 in FIN atm :letitout:... costs me ~100 euros to fill up the E30 ffs :hitler: :curse:
