i need some tech help with a shitty chrysler
  • trashcop 80s 80s
    • Jun 2004
    • 1130
    I am trying to fix my girlfriends car. It is a 96 Chrysler Cirrus with a 2.5 6 cylinder. It is misfiring on cylinder #4. I have replaced the plug and wire on that cylinder as well as the distributor cap and rotor. The thing is still misfiring and the ECU is still reading out a cylinder 4 misfire code after I erased it. I noticed that there is a sparking sound coming from the cap randomly, don't know if that should normally be audible.
    The car doesn't seem to misfire every time, maybe every 2 or 3 rotations, and it doesn't seem to misfire in the higher rpms unless under load uphill.
    Please help me fix this POS thanks
  • Dave
    E30 RAT
    • 11675
    there is a mopar related forum - I used to go there when I still had a Chrysler van for a utility hauler. Good info can be had.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • trashcop 80s 80s
      • Jun 2004
      • 1130
      do you remember the name of the forum because I haven't been able to find any good ones
      • Dave
        E30 RAT
        • 11675
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Helmetboy01
          • Nov 2005
          • 41
          Find the nearest high cliff, put the car in neutral.....push as hard as possible.......problem solved!
          • Nick325is
            • 1409
            I can get some info for you tommorow from one of my buddies who works at a Chrysler dealership.
            I am in the same boat as you as far as fixing my Gfs car. However she owns a K car and we are in the process of turboing it since the carb died.
            Nick
            • george graves
              • 19997
              Solution: Get a new girlfriend!
              (come on you knew you were going to get crap!)
              Originally posted by Matt-B
              • trashcop 80s 80s
                • Jun 2004
                • 1130
                she got the car for free last year. I hate working on this thing, removing the whole intake manifold just to change plugs sucks.
