1987 Volvo 240.....hating life.
  • slammin.e28
    שמע ישראל
    • 12054
    Long story short, overdrive went out. He replaced the OD relay. I replaced the solenoid and wiring. Fuse is good. Still no OD.
    WTF?
    I hear the relay behind the dash click too.
    I really, really hate this car.
    Any thoughts?
    This hulk of Swedish metal is taking up the lift...where my e24 should be.
  • VinniE30
    • 2113
    Since when did you have a volvo 240? picsssssss
    Zinno '89 <24v swap in progress>
    • slammin.e28
      שמע ישראל
      • 12054
      Lol, it's not mine. I'd never get one unless it was a wagon and a 5sp. I'm just working on this thing for a friend and had planned on putting my 6er up to start taking the 30 year old suspension apart....but NOOOOOOO. Foiled by a Volvo.
        • 37833
        You sure it's not just the wiring to the OD button?
        Grover Beach, California
        BimmerHeads.com
        • dirty30
          • 3052
          those OD units are trash, mine used to slip in and out of OD all the time on the highway when it encountered any sort of load (hill etc.)
          • slammin.e28
            שמע ישראל
            • 12054
            As in the wiring going up the shifter itself?
            I replaced the wire going to the solenoid. It was completely stripped.
            I read that after putting a new solenoid in it you have to drive it. There's no tach in this car too. I just had it up on the lift and let it run through the gears, but when I'd hit the OD button the light would come on, relay would click, but I'd hear and feel no change in the engine noise.
            ....then the goddamn manual window decided it didn't want to go back up so the M3 had to sit outside in the thunderstorm last night. :hitler: I was livid.
            YUS! Shoulda just gotten the IPD delete plate and been done with it, but nope.
            • Mr. Burns
              • Aug 2011
              • 3516
              is this the 4speed manual with push button OD?
              mine went in my 740turbo, but replaced the selonoid with a j/yard pick and was working fine again...
              it's not that complicated of an affair untless there is something mechanically binding it to no longer move
              Originally posted by flyboyx
              i have watched my dog lick himself off a few times
              • slammin.e28
                שמע ישראל
                • 12054
                No, it's a 3sp auto, IIRC.
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  oh, well shit.
                  hit up turbobricks.com
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    oh, well shit.
                    Word. Are 940s the same setup as the 240s? Seems most of the search results roll up 940s.
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      is this for you? or a client?
                      what's the budget like?
                      TIME FOR A 5.0 SWAP!
                      or, use the factory b230 engine, get a t5 adaptor plate and toss on a cheap ford t5 transmission.
                      more info here-->http://www.v-performance.com/products/transmission.html
                      FAILING that..
                      narrow your searches down on t-bricks using the acronymes
                      there is a tech 240 forum, but all engines with with auto tranny's are typically defined as b230 (engine)+ AW71 (auto 3 spd) tranny...
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        FAILING that..
                        Friend's car. Budget is nil. He'd like to do a 5sp swap, but I'm not down for that BS unless he buys me a trans jack.
                        Apparently he wants to get the car tonight, so I'm throwing in the towel. Not my problem anymore.
                        • ethirdy
                          • Nov 2007
                          • 406
                          Disconnect the solenoid. See if it works. Without it connected, it's the same as the IPD blockoff. takes the button out of the mix, too.
                          Originally posted by alpinaclone
                          Since the real economy is in the shitter, I say we start our own.
                          This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
                          • ohthejosh
                            • 4963
                            Bring car to Ikea, ask for refund.
                            SO MUCH MORE TO DO!!
                            IG: ohthejosh
                            LEGIT CHECK ME BRUH
                            BUYER FEEDBACK THREAD
                            • JinormusJ
                              • 6887
                              Because Lolvo
