Ignition Keys
  • NV325i
    • May 2012
    • 236
    Ignition Keys
    So I went to the local BMW dealer to have a new key cut (I have a blank ordered from pelican parts) and I was told that I have to leave the key (the only one I have) with them and it was going to be sent to New Jersey with a 3 day turn around. Does this seem right or can I just go to a locksmith and have them cut it. Anyone else have the same issue, I really don't want to give them the "only" key to my car (and it being unusable for 3 days).
    Current: '92 325i Vert
    Past: '84 Euro 320i -Had to leave in Italy
  • blocke
    • 1305
    Shit I had a spare key cut at True Value hardware. The ignition key is not chipped or anything. Its just a regular old key, like your door to your house.
    Take it to Home Depot, or ACE hardware..something like that. Should be like 4 bucks
    Parts Wanted
    The Never-ending Resto Mod
      If you have a new key, a good locksmith can cut your blank to that pattern. I would not try that with a well work key. A new plain master key from BMW isn't expensive.
      • NV325i
        • May 2012
        • 236
        I have the uncut master, but the one I do have has twenty years of wear on it. No chips or breaks, just well used.
        • jw 325ic
          • Sep 2006
          • 1360
          Local key cutters here wont touch bmw steel keys. They say it ruins their blades or something :). Good luck, most places will do it once but then never again.
          • e30vert
            • Jan 2005
            • 1789
            Ive posted this before.
            Go to dealer with VIN
            Provide Dealer VIN number at parts counter and ask for the KEY CODE.
            Write it down. Leave and say thanks
            Go to a reputable locksmith in your area. Tell him you have an older BMW that uses a non chipped key and you have the code.
            Give them the code
            Watch as they cut all the bumps and ridges.
            Pay 8-12 dollars.
            Leave with smile on face.
            • slammin.e28
              שמע ישראל
              • 12054
              As long as your locks are original to the car I'd just order one by VIN from the dealer. This is the reason I keep the VIN from the donor car if I need to swap locks/ignition.
              • NV325i
                • May 2012
                • 236
                So the counter guy at the dealership was full of shit when he said he had to have the original key too and send them both to Jersey.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  Yes. There is a big database in the Fatherland with every key code and VIN. Usually it's like 2 days, although they'll tell you two weeks.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    I cut mine at local ACE hardware store for $3.75. They have blank brass key, which is not as good as OEM, but for the price you can cut 10 keys and never worry about losing/breaking your key again.
