M90 motor swap?
  • Silverdogz
    • Aug 2012
    • 168
    M90 motor swap?
    Just looking around craigslist for some parts and found this E30 with and M90 motor??
    so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
  • slammin.e28
    שמע ישראל
    • 12054
    That little car is probably quick as shit. M90 was in Euro e12/e24 M535 and 635Csi from ~'78 to ~'83, give or take for each chassis.
    It is spectacular.
    Personally the M90 is my favorite M30 variant. I've got a head from one, and I've got a B34 block to be bored to 94mm for some flat top VW pistons to make a M90-esque engine.
    • euroshark
      • Apr 2006
      • 3491
      I built this car a few years ago. It was quick as shit.
      • F34R
        sLaughter
        • 12376
        Diarrhea quick?
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • slammin.e28
          שמע ישראל
          • 12054
          Originally posted by F34R
          Diarrhea quick?
          With an M90....It's probably at the projectile diarrhea level. That's past explosive. ;)
          • F34R
            sLaughter
            • 12376
            With a turbo I would believe that.
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
            • Robotin
              • Jun 2011
              • 4471
              says the m90 is a weaker version of the m88.
              only 215hp.
              i would rather have a m30b35 with bolt ons.
              1989 325i SETA stroker [delphin] R3V'd 8/31/2011
              1989 325ix [zinnoberrot] $OLD
              1970 2002 [Nevada]
              Originally posted by Herr Faust Schinken
              guy must have slid into something that doesn't look like a car vs car hit
              Originally posted by ak-
              Must of slid into Rob
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                M90s have lighter weight internals, higher compression and like to rev more than m30s. Plus they make more power IIRC than a stock m30b35.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  Originally posted by Robotin
                  http://en.wikipedia.org/wiki/BMW_M88
                  only 215hp.
                  Same cam as the B35.
                  Pretty much M90 is a bored/stroked B34 with B35 cam. Or an M88 with a B34 head and B35 cam. This is probably a bit over simplified, but it's still a badass engine.
                  • kronus
                    • Apr 2008
                    • 13031
                    M90 is a big bore, short stroke engine. 94mm pistons, the head and cam are similar to a b35. Looks like that car is still l-jetronic which is unfortunate, would take a cam swap to get motronic 1.3 but that should give a nice power boost.
                    M90 is known as the "dirty" euro engine.
                    cars beep boop
                    • euroshark
                      • Apr 2006
                      • 3491
                      1.355mm Bigger bore and a 2mm shorter stroke than a B34 or B35. They are more eager to rev than the standard M30. An M90 + G265CR equipped 635CSi will beat an M6 / M635 to 60 and sometimes beyond thanks to it's excellent torque curve.
                      • kronus
                        • Apr 2008
                        • 13031
                        Didn't know that! Looks like I have some drag racing to do :p
                        cars beep boop
                        • VinniE30
                          • 2113
                          They don't appear that special to me. I guess it's more of a novelty.:)
                          If the only big difference is that small change in bore/stroke and compression, while having an older version of motronic, I seriously doubt it would even come close to being as fast in an E30 as a modded B35 like mine.
                          How do you figure it would be faster than an M6 assuming they're in the same chassis? The M88/early S38 would make much more power.
                          Zinno '89 <24v swap in progress>
                          • euroshark
                            • Apr 2006
                            • 3491
                            The earlier cars actually had L-Jetronic and were much more responsive. As for being quicker than an M6 to 60, it all comes down to the torque curve. The M90 makes ~90% of it's peak torque from about 1800rpm to about 5000rpm. The M88 and S38 make more peak torque but it comes on later and more abruptly, essentially making it take longer to wind up. I can tell you they are quicker from first hand experience! Quicker than a US Spec M6 and as quick as an M635. This car was a blast... I wish I would have kept it, but at the time it had to be sold so I could buy the '83 635CSi Euro that I have now.
                            • F34R
                              sLaughter
                              • 12376
                              That euro 635 is so sexy.
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
