ix vs i parts question
  • Horton
    • 16
    I have a question about engine part similarities between the ix and i. Does anyone know if the engine wiring harnesses are interchangeable? Could parts needed for an e2i swap be pulled from an ix? Thanks!
    • 34844
    The oil level sensor wiring is different and there is one more pin in the c101, which you can ignore. But it should work just fine.
    • mkcman17
      • Jul 2010
      • 8240
      what parts are you pulling? the trans/oilpan/dipstick/mount stuff is all specific.
      1989 LN106 Hilux / 3.0TD SFA
      1974 2002tii / stock
      2002 IS300 / 5spd LSD
      • Horton
        • 16
        Thanks for the info. I was looking at a complete topend so head, intake, fuelrail, harness and ecu as well as a bottom end. I know ill need a crank, pistons and oilpan and that the ecu wont work. I wanted to build one up then drop it into my ETA. so will the harness work if I ignore the extra pin and use the is oil level sensor? I found cheap ix parts so that's why I am considering this.
        • mkcman17
          • Jul 2010
          • 8240
          you should be fine. my ix had a 153 dme. remember, if your car is pre-10/85 you'll need a fusebox adapter anyway.
          • Horton
            • 16
            Cool, I'm pretty dang excited for this swap
              • 34844
              You can use the ix manual trans for rwd, it has the ears for regular trans mounts. You need a driveshaft with a 96mm guibo flange.
              The ix ecu is the same as any m20b25
              • Horton
                • 16
                Thanks Nando, thats good to know.
