Swithing from synthetic to Rotella 15w-40
  • Jaxx_
    • Dec 2009
    • 1880
    Originally posted by stamar
    thats why I think he has a 318 ic
    yes, the question is whether the car is M42 or M20...
    • Vivek
      attention whore/retard/bitch
      • 6167
      He has a 325ic, I'm assuming it has an m20.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • stamar
        • Apr 2011
        • 1362
        I recomend the OG mobil 1 million mile 15-50w oil with the zinc.
        Even for summer only driving. change it once a year.
        not the rotella. You actually have a car you should sell at auction and dont drive it.
        dont worry about saving bucks on oil youre throwing about thousands by driving it at all.
        • glucklich21
          • 1912
          If your vert has the m42 bmw recomends full synthetic oil 10-30
          theres no way to tell from your post although a 92 318ic is rare
          for the m20 I still recomend full synthetic 15 50 mobil 1just changing at 6k miles. make it a lifetime vehicle. dont even let thinner diesel dino oil touch that thing.
          oil nerds would love to have a zero wear engine like that Id sell it if I were you.
          Please show me where in your M42 powered E30 manual it calls for 10w30, let alone synthetic, in anything above freezing temperatures outside.
          • stamar
            • Apr 2011
            • 1362
            is there such a thing as an m42 e30 manual?
            bmw recomends synthetic oil for the m42 and the m50. absolutely every manual they are in.
            It is made for synthetic oil the first generation of engines.
            google up the viscosity i think it says from 0-40 to 15 50 even so basically all oils but 20 50
            google up what m42 people use. I personally think its rude to ask people to look stuff up for you without pay.
            Show us your m42 offical statistics thanks.
            google up any what oil to use thread
            • glucklich21
              • 1912
              You must not understand sarcasm. Of course there's a M42 manual, it's sitting in my glovebox. It's the same as the M20 version except with M42 additions such as engine layout diagrams, specs, etc. If you turn to page 61 of said manual there's a little diagram with various viscosities listed and their correlation to outside temperature. In the range of 20w50 is 14 through 120 degrees. This is the vis. I run in my M42 powered car. Anything thinner I have found makes the engine start to tick after driving it for awhile in 95+ degree weather. As for "googling" you will see that's what the majority of people run. So your 10w30 recommendation for a M42 is completely inaccurate.
              Also worth noting is that no where in this manual is synthetic mentioned. So I call BS unless you show proof, ie: a BMW technical bulletin.
              And to the OP, 15w40 should be just fine for your climate and Rotella shouldn't be a problem. I run it occasionally if I can't find Delo 400. ;)
              • stamar
                • Apr 2011
                • 1362
                there are so many sources to tell you youre dead wrong from google i can only assume you dont know how to use it
                http://www.bmwe36blog.com/what-type-...y-bmw-e36.html
                whatever guide you are following has led you to a bad place. Go ahead and ask any of million m42 owners what oil to use.
                according to this it came with 5-30 from the factory. you have the one guide you should never follow the one that is wrong. ask all the m42 owners what they use
                better yet type in google what type of oil goes in my m42? most m42 are in e36 and you need to look at their guide. Your welcome for looking up for you, your cars oil.
                I call you an idiot.
                dont sidetrack the thread with your own questions go make a thread and ask the owners what you dont know
                man I dont have this kind of time to waste but the worst combination in the world is rude and ignorant and they always seem to go together.
                Im dying to hear your oil advice. Definitely write this guys oil advice down on diesel oil.
                • stamar
                  • Apr 2011
                  • 1362
                  I went ahead and asked someone who looks at the bobistheoilguy blackstone lists\
                  and it says it like 5-40 or 15 40 not 10-30
                  it likes the 40 number and various brands. Definitely ask there for your specific car. which in this case is not the op its the random troll.
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    i like this guy
                    • stamar
                      • Apr 2011
                      • 1362
                      I went ahead and pulled out the e36 bentley manual for you buddy
                      and it recomends 2 different viscosities. it recomends 5 -30 and 15-40 depending on your climate.
                      page 30, for the m42 and the m44 e36 318. It says on the chart "BMW SPECIAL FLUID RECOMENDED" not required it says api sj energy saving fluid. BMW was the first manufacturer to recomend fully synthetic fluid, but not require it. Its required in the m3 and m5.
                      That was up to date as to the time the m42 was made.
                      it has a chart that would seem to suggest 15-40 is better for most climates though definitely.
                      • stamar
                        • Apr 2011
                        • 1362
                        thats crazy I just read through 10 threads and all of them said never use 20-50 oil, use 10-30 or 10-40
                        and Im looking this up for you because Im concerned for you not knowing how to read. I dont even own this car. And right now I own 4 cars and should probably be looking up what to use for the next one Im changing.
                        • stamar
                          • Apr 2011
                          • 1362
                          dude whats so retarded about this advice even is that the op has a different engine than you. he has an m20. So you would like to advise him on what to use in his m20 based on what you use for your m42?
                          thats like taking putting d cells in your walkman because your flashlight is working.
                          Get out of here dude. Be quiet we dont care dont be giving people advice on what oil to use. Its all good.
                          • glucklich21
                            • 1912
                            Once again I went completely over your head apparently. Does the car in this photo look like an E36?
                            And if you knew anything about the timing components in the specific M42 version that came in an E30 you would be familiar with the issues that come from running thin oil such as chain noise, lifter noise, and other terrible noises as valve train shouldn't make.
                            Now for your links, maybe you should go take a look around M42club instead of posting links from the top 3 google results. Also while you are perusing the internet go take a look at what Chevron says about their Delo 400, it goes along the lines of backwards compatible with gasoline engines.
                            Synthetic is a completely different beast and you stated BMW said in the manual to use synthetic, it does not. The E36 manual may, but this isn't an E36, it's an E30. The E36 had 2 different revisions of the M42 from the E30 in its chassis, let alone the M44. Different designs require different standards.
                            As for him having a M20, I find that irrelevant at this point. It uses the same viscosity chart, but people run all kinds of things in a M20 with success, the joys of a timing belt I guess.
                            I would also like to point out watching your backtracking has been quite the entertainment early this morning.
                            • stamar
                              • Apr 2011
                              • 1362
                              If the m42 in the e30 requires different oil than the m42 in the e36.
                              I have never heard of this. I will stand totally corrected if this is the case.
                              I know its not. However if there is anything that suggests that it is, bring it to r3vlimited, and let the ops and experts here verify this. I will be the first one to admit I must be wrong.
                              I will write a long poem to your brilliance.
                              the m20 uses the same viscosity chart? No look rocket scientist, the guide you have is incorrect, it is using the m20 oil guide and not the m42 one.
                              the m42 chart has 15-40 as the oil that goes off into infinity. Meaning never use an oil thicker than this it is never required.
                              all e30 m42 owners know to use the e36 manual ( thats why I have it downloaded because so many people have questions about it not in the bentley)
                              Dont take my word for this ask anyone.
                              you are indeed the only m42 e30 owner in the world using the chart from the actual e30 owners manual from 1991. Everyone else knows that its wrong.
                              • sweet6e30
                                • Feb 2011
                                • 531
                                I run these depending on how im feeling with my heavy foot!
                                Liqui Molly 10-60 RACE FUll syn. AMAZING and PERFECT <---- this is really good stuff not cheap but great for lapping/drift where temps can run high and your beating it!
                                Liqui Molly 10-40 syn : everyday driving and heavy foot action!
                                Motul 15-50 syn : track and heavy foot street action
                                Mobil 1 15-50 syn :track and heavy foot street action
                                Ive even run 10-30 and 10-40 Valvoline Syn just fine
                                In all due respect any 10-40 SYN oil will be great even with a heavy foot, these motors are tough; remember that.
                                Do your oil changes often and your bearings and valve train will give you the love back!
                                when it comes down to it, its about common sense, and peace of mind. A healthy engine to start with that is well maintained : you can't go wrong.
                                Ill be honest, Ive seen alot of disasters and shitty ghetto maintained engines. from the past 15 years of mechanical experience. People neglect alot and then stand there like a moron wondering why the've overheated, or it wont start, or why a rod is knocking, etc..
                                So maintain your motor, replace worn parts, and use your noodle when it comes to changing your oil.
                                just my 2 cents
                                my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
