e36 motor and trans help
    Hey guys i am possibly buying a E36 M3 motor and transmission and i was going to swap it into my e30... what all would i need to buy to make sure the motor and trans fits in properly
    thanks in advance
    http://www.r3vlimited.com/board/forumdisplay.php?f=129
      crisco, a shoehorn, and leverage.
        Which is also known as the Blunttech Saturday night special.
          Let me tell you, Blunt's Saturday night special has NOTHING to do with cars.... ;);)
            BWAAAA-HAHAHAHAHAHAHAHAHA!
            OP, what year is the M3 motor? If it is a `95 (S50), it's OBD1. If it's a `99-`97 it's OBD2, and will required more work to run.
            Good luck!
            Originally posted by LJ851
            kingston is the play by play announcer for this thread.
            ‘Tis by the grace of God that my cars run!
            Originally posted by unloadedak
            #teamross
            Siobhan's Build Thread - UPDATED!
              if you cant do the research to find things like this out on your own, you should seriously consider hiring someone to do the swap for you.
              AWD > RWD
                Its a '94 motor... i have a couple people that will help me i was just thinking ahead to see what i need before i buy the motor
                  OK, well it's OBD1, then. You will need the full engine harness, a different brake booster, a wiring harness adapter, custom exhaust downpipe, E28 or 24V-swap specific custom motor mounts. You will need a different driveshaft. Some people run the can clutch with this swap, others pop on an electric puller or pusher fan (or both). You'll need the DME as well as some other minor
                  parts, but this gets you most of the way there.
                  Of course, you should take care of as many gaskets & seals in the engine, trans, diff, etc, as possible.
                  Oh, what diff do you have? If you're going from a Getrag260 to a ZF transmission, you will probably want a different diff. 3.46, 3.25...higher than that and you'll be hating life
                  #teamross
                    No M3 was sold in the US for 94 model year. Only in Europe and Canada and the engine was much different from that model.
                    Originally posted by mbonanni
                    I am a pursit now.
