Feel So dumb..
  • Zreberlcoe
    • 1555
    Feel So dumb..
    How do you get the stupid rear defrost switch out?
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • Blackout
    • Apr 2011
    • 4130
    Pop the blanks out to reach behind it and push it out.
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • Zreberlcoe
      • 1555
      I tried and I don't know how to do that without messing up the console with a small flathead or something.
      BMW
      • bmwstephen
        • 2463
        remove your radio, reach under and pop out
        • Zreberlcoe
          • 1555
          okay this is getting worse. How do you take out the radio if it's aftermarket?
          BMW
          • AntiScope
            • 401
            Pop the outer trim off, then on each side you usually have to stick a special tool in far enough to release the headunit from the metal harness. If you can find something skinny/long enough, you can use that instead. You'll know when it's released, it should slide right out.
            • bmwstephen
              • 2463
              it should've came with these 2 sliding prongs you insert on the side of the unit (between the metal cage and the unit itself). It will release the unit from the cage and you just pull it out.
              • jaywood
                • Jul 2010
                • 4528
                To remove the radio you'll need the special keys designed for the radio. I didn't have any so I went to the local audio place and they let me borrow their keys.
                You can remove the OBC pretty easily and possibly pop it out from there if you can reach.
                Or a very strong, small suction cup :p
                • hyperE30
                  • Sep 2009
                  • 2202
                  Just get a very thin flat head and pop a blank first from a corner and them push the defrost out.
                  HyperWerkz
                  89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
                  " enjoy the show "
                  • Zreberlcoe
                    • 1555
                    Thank you..
                    BMW
                    • 325ix
                      • Aug 2009
                      • 7783
                      This, it is a ridiculous wast of time to pull anything out to do this job.
                      • Zreberlcoe
                        • 1555
                        Alright I got it. Thank you guys. I did just take out the stereo which was good to learn that the PO gave me the box to the stereo or else I wouldn't have been able to get it out! But I did move the switches into other slots, is there any harm with that?
                        BMW
                        • ButtJuice
                          • Dec 2009
                          • 2609
                          Take out your OBC, easy.
                          1991 318is - Sold
                          1986 325 - Sold
                          Instagram - Lamoursum
                          • TimKninja
                            • 2131
                            Take the dash out, should be able to reach it
                            After that .
                            1985 325e M50TU(Sold)
                            1991 318is Slicktop (Sold)
                            1990 325is Brilliantrot S50/5 Lug Swapped.
                            1992 525i Manual shitbox Winter Beater
                            • future rs
                              • Aug 2012
                              • 514
                              After that .
                              It's best to remove the transmission and reach through the shifter hole.
