How long before rebuilt engine rings seat? EDIT. Help a 1st time engine builder.
  • brianao34
    • Jun 2010
    • 660
    #46
    Originally posted by whodwho
    You must of missed my post ;)
    I was ignoring all the "ring" posts. I was in denial.
    So why might the rings have not seated? It seems to be warlock magic that no one really can explain.
    • brianao34
      • Jun 2010
      • 660
      #47
      I think the next plan of action is to pull the exhaust manifold back and see if it's all 6 cylinders burning. Spark plugs say yes.
      I'm also mentally preparing myself to tear it apart again to get at the rings. The engine has 350 miles on it, will I need to take the block back to the machine shop to get it rehoned? Or can I just get one of these "glaze busters"?
        #48
        Originally posted by brianao34
        - Barely smokes at idle, smokes like a train under full throttle
        That sure does sound like rings. Were the cylinders gauged to make sure they weren't worn past the limit? Was the block cross-hatch honed?
        I guess the people that rebuild engines all day and master mechanics aren't usually forum-goers. :/
        That is probably a fair statement, but there are some folks around that more than a passing knowledge of this subject.
        • brianao34
          • Jun 2010
          • 660
          #49
          Well I was informed from the machinist (a competent guy referenced from my buddy) that I could use standard pistons and rings because he barely had to hone the cylinders to get them round. And I rechecked the ring end gap when assembling to confirm that the standard size rings were usable.
          Yea, I would say majority of people here, if they have any experience with building engines, would only have first hand experience with the few engines they've personally built. I need someone with lots of hands, and brains
            #50
            What I'd want to have known is what the piston to cylinder clearance was. I don't have any data at hand for an S50, but I'd guess it would not be all that different from an M20. Which from memory is something like .004 to .0015. It doesn't take much wear to get beyond that range.
            Another factor could the condition of the ring grooves in the pistons. If there's wear there the rings aren't going to work right. And then there is a possibility that the rings might not be "right" for the engine. I only use OE/OEM rings and don't know anything about the various aftermarket ring sets.
            What was the mileage on this engine?
            Engine work isn't "rocket science". It is really just a matter of having the data to know what the tolerance & wear limit is and having the tools to make those measurements. When it comes to having engine work done, even at a top notch shop, my philosophy is trust but verify.
            One can get away with quite a bit on a street engine and have an okay result, but if you are building a race engine there is no wiggle room. BMW's engines are built pretty close to race standards and if you want to have a good result you need to equal or exceed that level of perfection.
            • brianao34
              • Jun 2010
              • 660
              #51
              That was my first mistake on my first build. I didn't get any hard numbers from the machinist, just, "standard size is good." As far as the bearings, I plastigage'd each one and they were all well within spec. I assume that after checking the ring end gap that would tell me that the cylinders were within spec.
              Mileage was unknown. The engine was pieced together. The block according to the previous owner was recently rebuilt and R3v-shifted and cracked #4 cyl. I had the cyl resleeved and after some research and inspecting it it looked like he did a great job.
              Yea, it's not rocket science at all, but then again as a first time builder you run into things like, is the piston skirt too scored? Or, this piston ringland has a slight imperfection, can I just file it smooth or is that something that shouldn't be done? That's my problem, I have no one close to me that has done it to ask simple questions that I end up searching for hours on the internet before I see that one guy says, "it worked for me."
              I've learned a lot plenty from this build to use on my next one for sure.
              • butters
                • 1205
                #52
                Interesting, I wouldn't have guessed that sleeving is cost effective on these blocks. Have any pics? Just out of curiosity.
                • brianao34
                  • Jun 2010
                  • 660
                  #53
                  No, I don't, but from the looks of things I'll be tearing this one down so I'll snap one then if I remember...
                  I don't remember the price but it was $150 or so.
                  • butters
                    • 1205
                    #54
                    Not bad.
                    I feel your pain in terms of post-rebuild struggles... it sucks now but once you get to the other side it will be well worth it and you will have learned alot. Good luck on the re- rebuild.
                    • brianao34
                      • Jun 2010
                      • 660
                      #55
                      Thanks man. It's hard to laugh now.
                      After I got back from the test drive I just laid on the concrete on the verge of tears. I miss my creaky old car.
                      • Raxe
                        • 5346
                        #56
                        I know how you feel. Depends on your personality, but maybe it's better if you can wait a bit and take a break before tearing right back into it. These projects are supposed to be enjoyable; if it feels like a chore and you're dreading it you'll just wind up hating the car in the end, or worse yet you'll plow through it and risk making more mistakes and blowing more money.
                        Either way good luck with the next round.
                        • efficient
                          • Feb 2012
                          • 3312
                          #57
                          damn im worried about doing this now. but i cant turn back cus i already bought the parts.
                            #58
                            Plastigauge is okay for a crude sanity check, but when it comes to bearings the only reliable method is to measure each journal and pick the "color" of bearing that results in the correct clearance. If you are lucky one "color" of bearing will work for all of the mains and rods. But it isn't uncommon to need bearings from two or more "color" sets.
                            A ring gap check only tells you that the ring gap is correct at the top of the cylinder. It says nothing about how much wear the cylinder has, which will be at the bottom.
                            A cracked cylinder from an over rev? That block is maybe good enough to be a buoy anchor, but certainly not good enough to be a motor.
                            It is really simpler than that on a BMW engine. Piston skirt scored, new pistons. Ring grove damage, new pistons. Bore damaged or worn beyond spec, overbore & new pistons. Crank journal out of round, scored, or worn below minimum, new crank. Cam worn or scored, new cam. Etc.
                            • brianao34
                              • Jun 2010
                              • 660
                              #59
                              Your arrogance concerns me.
                                #60
                                I think what I said is pretty much what any engine builder would have said. It isn't arrogance.
