How long before rebuilt engine rings seat? EDIT. Help a 1st time engine builder.
  • tinkerputzer
    • Jun 2008
    • 508
    That kind of oil consumption is not from a rings failing to seat but most likely oil contol ring installation problems. What kind of oil control ring set did you use?
    • brianao34
      • Jun 2010
      • 660
      Originally posted by Dj Buttchug
      I think you are correct in that the mystery oil added in the cylinders is the reason. Most BMW engines require the rings to be installed dry into a dry cylinder wall.
      FUUUUUUUUUUUUU
      Yea, it's little facts like that that you never know about until afterwards. Ha...
      It was a one piece design from Deve's.
      • tinkerputzer
        • Jun 2008
        • 508
        Oil control ring probably isn't the problem then.
        • brianao34
          • Jun 2010
          • 660
          Do you mind explaining your train of thought for that?
          • tinkerputzer
            • Jun 2008
            • 508
            The one peice oil control ring is pretty hard to screw up (unless it is gapped wrong) vs the three peice which has an expander ring that can easily be screwed up.
            • BlackbirdM3
              • 2773
              It took me a good 300 miles on my Datsun engine the first time I rebuilt it. I was also using Deves rings at the time. I knew exactly when the rings seated because the sound of the motor changed slightly and it started pulling like a freight train. If I remember correctly, the oil consumption was a bit on the high side till that point. I was also keeping the revs below 4k rpm, and didn't go above that till 500 miles, adding 1000 rpm for every 100 miles after that. I thrashed on that motor and never had an issue. I think that build was better than the current one I did 2 years ago.
              Never use a synthetic oil for the first 3000 miles. I've been told that by various machinists and engine builders who know far more than I do.
              Will
              '88 BMW M3
              • TobyB
                • 5298
                Burned 5 quarts of oil today driving hard for around 75 miles.
                You have a more serious problem, then. Even a poorly- seated set of rings
                won't burn THAT much.
                Sorry.
                And every set of rings I've used have said to use motor oil as an assembly lube.
                Yep, no synthetic first load. But DO use a break- in oil from a reputable distillery...er....
                t
                  • 34847
                  Originally posted by TobyB
                  ...and I'm a big fan of the 'warm it up, and get on it' method.
                  Done 5 or 6 engines that way, and they always seal well. Better than the constant idle...
                  ...and the cam doesn't mind, as long as it doesn't idle below Jim's 2500 or so.
                  If yours is still burning oil at 120 miles, warm it up and do a series of 6k pulls
                  at wide- open throttle, with a 'lift and coast' with closed throttle.
                  What I've found, on everything from M20's to G72's...
                  t
                  this is what I do as well. warm it up, then drive it like you stole it. the only real no-no is extended time at high RPM (like trying to top out a car powered by an M20).
                  • brianao34
                    • Jun 2010
                    • 660
                    So, I did a leakdown test last night and:
                    1:5%
                    2:10%
                    3:10%
                    4:30%
                    5:15%
                    6:10%
                    Should I be seeing single digit numbers on a fresh rebuild? or is 10-15% good?
                    I'm going to re test it tonight when I get home, I think the cylinders had a little oil in them I believe.
                    • brianao34
                      • Jun 2010
                      • 660
                      Just talked to Frank at Deve's Piston rings (where I got the rings)
                      He said because my compression numbers were so high and consistent and that it doesn't smoke at idle that he'd bet its the valve guides/seals.
                      Going to re-leak test and go from there.
                      There's hope yet!
                      Also asked him about using the Marvel Mystery Oil and he said that shouldn't have been a problem.
                      I'm really thinking it's something in the head considering the car pulls HARD, just smokes.
                        1:5%
                        2:10%
                        3:10%
                        4:30%
                        5:15%
                        6:10%
                        5% or less on a fresh rebuild is what you should see. 10-15% is what you should see on a used engine that doesn't have excessive wear and would be barely acceptable on fresh rebuild. The 30% number means something is seriously wrong.
                        • brianao34
                          • Jun 2010
                          • 660
                          Great, thanks.
                          • BlackbirdM3
                            • 2773
                            You could try doing a dry compression check, then add a little oil into each cylinder. If the number comes up, its rings, if it stays the same, the issue is in the head. With the leakdown, you should be able to hear where the air is escaping to. Its hard to pinpoint sometimes however.
                            Will
                            '88 BMW M3
                            • brianao34
                              • Jun 2010
                              • 660
                              Will
                              Yea, I'm almost sure it's got to be valve seals and possibly guides after reading around and talking to that guy. Because the engine pulls really hard and I have no smoke at idle.
                              And I should have mentioned before, when I did the leakdown, the only place I could hear air escaping was through the oil filler cap/dipstick.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                Sorry to be the bearer of bad news, but that means the air is escaping into the crank case - usually means rings or a damaged piston.
                                john@m20guru.com
                                Links:
