Making a solid mounted race shifter?
  • JFarhanbod
    • 2151
    Sup guys I want a shifter like the AKG or Bimmerworld one but its really out of my price range right now. Could you just take a square piece of metal, drill the 3 holes for the mounting screws, one big one for the shifter and weld the cup onto there?
    I also saw someone mention that you can get a early shifter carrier and cut it to size and mount it on top but I also saw that newer style shifters wont fit so thats kind of a bust
    Any ideas?
  • semaj4712
    • Mar 2012
    • 3069
    whats wrong with getting a short shifter...then save money for a quickshifter, theres one on rev for like 300 bucks, akg
    29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
    72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
    Gewerkschaft der Polizei Sticker/Clings For Sale $8
    • Roysneon
      • 4505
      I'm sorry if I sound like a dick but...
      Either save up until you can afford a used one or go without. Unless you have a good idea and the skill to pull it off then just pay for someone else's R&D.
      Originally posted by mbonanni
      I am a pursit now.
      • 10Toes
        Me Father Was A Tree
        • Jan 2008
        • 61222
        Any ideas?
        Just use a early sheet metal carrier and trim it down and bolt it in.
        Just don't use stock engine/trans mounts with it or the engine/tranny will move too much.
        • JFarhanbod
          • 2151
          ^was thinking that too but I heard newer shifters don't work in there
          • F34R
            sLaughter
            • 12376
            I doubt they would since you gain 2" by mounting it in the car. It is a cheap fast fix!
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • JFarhanbod
              • 2151
              So if I go the early shifter carrier route, what shifters would I be able to use? Just the early one?
              • 36brua
                • 689
                Info I saved... to use late shifter per photo above ^^^
                'Your car has the mounting points already. It mounts where part of the Automatic shifter mounts, and the rear mounts on the stud that holds the center console. I can't think of any downsides... I mean, this is how some of the DTM cars did it. I was even able to install the selector rod from inside the car, since there's no carrier in the way
                You've gotta have stiff/solid engine and tranny mounts or else the shifter will move around under hard braking/turning/acceleration.
                Installed a z3 1.9 lever and all new oem hardware in a metal console. No issues, very nice upgrade from stock worn out shifter.
                Buy 1 upper ball cup, 2 lower ball cups and sand one of the two lower cups down in order to fit all 3 in the metal console and lock with the circlip. Cut the upper ball cup with a sharp blade and slip on the shift lever. Replaced all worn out hardware and enjoy !
                http://www.realoem.com/bmw/showparts...85&hg=25&fg=05
                Lock Ring 06/1986 23411466112
                BALL CUP LOWER 25111207744
                BALL CUP UPPER 23411466110
                Lock Ring 23411466112
                Pelican had the cups if youre careful you can reuse the lock ring
                My CA legal M60 swap
                The happening in our garage
                • kronus
                  • Apr 2008
                  • 13028
                  I am running the sheet metal console with an E36M3 shifter and no problems. The shifter balls are all the same.
                  cars beep boop
                  • emerson.
                    • Jun 2012
                    • 482
                    I'm using a solid mounted e39m5 shifter. I didn't make it but its easy to do..
                    Originally posted by LowR3V'in
                    It's in the name e30tech not e30offtopic
                    • JFarhanbod
                      • 2151
                      Does it make a difference that the metal shifter carrier will be mounted from the top instead of the bottom? would the bottom of the shifter have to be longer to accommodate the extra inch or so gained or does it still work at an angle?
                      • JFarhanbod
                        • 2151
                        are you using the early shifter carrier? pics?
                        • kronus
                          • Apr 2008
                          • 13028
                          It works better, assuming you're installing a short-throw shifter, because the raised pivot point puts the selector rod at a more level angle. Also, it's a lot easier to install and remove from the top.
                          cars beep boop
                          • JFarhanbod
                            • 2151
                            this just got awesome, thanks everyone for the info
                            • emerson.
                              • Jun 2012
                              • 482
                              I'll get pics but I'm not taking my console out for them lol
