disassemblyhelp needed
  • gwb72tii
    • Nov 2005
    • 3864
    how do i disasemble the plastic clamshell around the steering column? there's only one screw i can find on the bottom that allows partial disassembly, but then it won't come apart just behind the steering wheel. looks like i need to take off the steering wheel, but it has an airbag.
    TIA
    “There is nothing government can give you that it hasn’t taken from you in the first place”
    Sir Winston Churchill
  • DarkWing6
    • Apr 2004
    • 7144
    I'm not sure if it is any different on the 318s, but I think there are two screws (1 on each side) connecting the 2 clamshell side together. I think these are set deeper into the plastic. I can double check on my car before I go home and I'll have Greg tell you.
    • gwb72tii
      • Nov 2005
      • 3864
      thanks
      • gwb72tii
        • Nov 2005
        • 3864
        just double checked and there's on'y the one screw on the bottom. i partially disassebled the lower dash and i'm at a standstill on what to do.
        • e30Matt
          • 5077
          Are you working on an E30? If so there's two screws holding the clamshell together.
          • Jordan
            • 12908
            You must remove the steering wheel.
            Once you do you will see the screws you need to remove.
            https://mtechniqueabs.com/
            • gwb72tii
              • Nov 2005
              • 3864
              how do i remove the airbag so i can get to the steering wheel nut?
              • Dave
                E30 RAT
                • 11675
                If you would you would find the answer on how to remove the airbag.
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
