1000 mile drive Sav to RI
  • Regnar75
    • Sep 2011
    • 483
    i will be driving from Savannah to Rhode Island the 28th. most likely via 95N for almost 1000 miles. what to bring (jumper cables, spare tire, jack, tool set, 10 cases of yuengling, pistol, camera etc) in order to make this trip safely/sanely? also any thing worth checking out along the way? more fun roads to take that may be shorter/bypasses/winding/less boring etc?
  • M-technik-3
    • 18946
    Might consider taking 81 to get away from the semi's and commuters. The road is alot more enjoyable and is away from the nightmares of DC and the Philly and the majority of NJ. While it may not be shorter it's 1075 vs 980 in distances.
    • kway
      • 1084
      ^ Truth. that's my preferred route also.
      I've only ever brought the basics with me on multiple several thousand mile trips and never had a problem. Enough tools to change maybe a water pump, belts, fuel pump, etc. anything more major than that and you're going to be fucked anyway. I keep a spare water pump/alt belt, and spare main and fuel pump relays in my car anyway, never added additional parts for a trip.
      If you know your way around your car and know that everything is in good shape, you should be ok. How many times has your car broken down since your last oil change? None? Then nothing will probably happen on a 1000 mile trip either. That's the way I've always looked at it, haven't gotten bitten yet.
      Keep your speed down in VA. Generally watch your speed everywhere, but you especially don't want to get bagged in VA.
      '84 318i - Lapisblau/Schwarz (in cryosleep)
      '06 330i - Titansilber/Schwarz
      • jrobie79
        • Mar 2006
        • 2526
        I've taken my e30 to LA from Boston twice, and from Boston to Miami twice...never had anything more than basic tools, spare belts, coolant, and fuses. I keep it pretty well maintained but i agree with kway on basics only.
        1991 318i ---- 308K - retired
        • Regnar75
          • Sep 2011
          • 483
          yea i drove from RI to columbus GA last year and found the trip very boring, also i know about VA, there was cops everywhere. thanks for the advice
          • TimKninja
            • 2131
            Drove my E30 1200 Miles to H20 and back. Only thing that happened was I blew a rear shock mount going through NY. Thankfully had a spare. It was a month old URO shock mount.
            Basic tools. Extra fluids. Extra belts. Make sure you spare is full of air. Make sure your timing belt is in good condition. you should be good.
            1985 325e M50TU(Sold)
            1991 318is Slicktop (Sold)
            1990 325is Brilliantrot S50/5 Lug Swapped.
            1992 525i Manual shitbox Winter Beater
            • E30SPDFRK
              • 5715
              Watch your oil pan once you get here.
              Byron
              Leichtbau
              • M-technik-3
                • 18946
                If you go the Rt 81 way be prepared for possibility of snow.
                • Boostesi
                  • May 2011
                  • 220
                  i second that, especially if your m/s50 swapped the roads up here are awfull.
                  sigpicFellow e30 enthusiast
                  Dont waste your time hating, aint nobody got time fo dat
                  1986 bronzit 325es- SOLD
                  1987 delphin 325i- parts car
                  1990 scwarz 325is- m50 drift slut
                  CHECK OUT THE BUILD!
                  http://www.r3vlimited.com/board/showthread.php?t=229234
                  • TimKninja
                    • 2131
                    Try driving through New York . Makes RI Roads look flat as my ex girlfriends Chest.
                    I will never complain about RI roads again.
                    • redsubdivisions
                      • Feb 2011
                      • 1762
                      1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                      2012 Passat TDI - DD Duty
                      2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                      • dougie30
                        • Apr 2012
                        • 1708
                        This
                        Me and my friends drove through NYC and over the George Washington to get to p
                        Mk1 madness, to make a long story short my friend bottomed out so hard in his mk1 cabby he cracked his 1/4 inch reinforced steel oil pan and had to get AAA to tow us home...
                        Oh yea and Newark nj is a scary place... Stay away from Newark...
                        M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                        • Regnar75
                          • Sep 2011
                          • 483
                          oh im born and raised 18 years in warwick RI. im just heading home for a few weeks so yea i know how shit the roads are there, takes 2 years to do 1 mile of road and its cracked and full of pot holes by the next winter. oh and every "repair" is actually just a small mountain of concrete in the road. definitely getting all tires ready to go as well as some spare fluids. belts i know would be important but im pretty shit at replacing them so hopefully everything goes well. im counting on everyone flying for the holiday season but am expecting traffic around new york as well as snow. thanks for the advice
                          • FLG
                            • Sep 2011
                            • 3165
                            If you have any issues near NYC feel free to contact me (i get my PM's right away) and ill do what i can.
                            Good luck!
                            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                            • iSOregon
                              • Sep 2011
                              • 248
                              this man
                              unless you know of some glaring issues, have some faith in your e30. Ive gone from portland to san diego and back a couple times. Youll be fine
                              Originally posted by BewWoo
                              That's what she said.
