Tig welding rates
  • Kozworth
    • May 2011
    • 1339
    Tig welding rates
    Hello r3v,
    I have had experience tig welding in the past. Issue is I do not have access to a tig welder. I have a couple aluminum parts I needed welded and wasn't sure what a correct rate was to charge. Need to weld intercooler piping, bov vband flange, oil pan tap for return line, etc.
    I would consider purchasing a tig because I enjoy welding but its not in the budget, and should be moving soon. Gotta pack everything into the e30.
    Thanks
  • brent5631
    • Jun 2012
    • 421
    Originally posted by Poor Adam
    Hello r3v,
    Thanks
    I would expect 40-80 per hour depending on the place. A lot of welding guys don't want to mess with a little job like that. Also, having good fit of the parts will make it easier and cheaper for the weldor.
    • deutschman
      • May 2008
      • 5958
      You should look around town for smaller family type welding shops. They will be more willing to do small jobs. A small shop here in SF CA welded some steering arms together for me after I cut them down for my 2002 project for $50. You should be able to find some one. If not there is always JB weld lol
      • sharky
        • Jan 2005
        • 2672
        My Fabricator charges 100 hr, cant see any reason why that couldnt be done in less than a hour if everything is marked, clean and ready to weld
        • Kozworth
          • May 2011
          • 1339
          I might have a hook up from a guy but we aren't buddy buddy but know each other well enough... So wasn't sure if it could be like a 6 pack kinda job. I know tig takes a good amount of practice and a steady hand but seems like I could do all the parts in .5 hours
          • ZekeTheSneak
            • 1562
            I think my guy charges like 90? Hes way to good and luckily were buds so I get a decent deal. My guy would gladly do all of that at the shop on the side as he builds race cars all day. I would search and try to find someone who is good and does stuff in the field ie Vbands and mandrel bends
            • LJ851
              • 7919
              Most welders i know wont say hello for less than $50.
              That being said, if you show up with shiny clean parts with tight gaps you can get a lot of work done for that $50. $50- $100 an hour for high quality tig is reasonable in my book.
              Lorin
              The M30 is God's engine.
              • der affe
                Technical
                • Dec 2005
                • 8452
                I usually charge $75 an hour with a 1/2 minimum. But i charge the actual time i spend. If it is something simple and quick, i charge less.
