rwhp vs crank hp
  • ja burna
    • Jun 2005
    • 358
    rwhp vs crank hp
    Does anyone know a formula or off the top of their head what 324 rwhp equates to in terms of crank hp?
    "Driving anything else would be uncivilised"
  • slammin.e28
    שמע ישראל
    • 12054
    Add 20%
    In general 20% driveline loss is the accepted #, but it varies car to car.
    • LJ851
      • 7919
      15-20 percent is usually whats used on a 2wd vehicle.
      Lorin
      The M30 is God's engine.
      • 10Toes
        Me Father Was A Tree
        • Jan 2008
        • 61222
        • IronFreak
          • Dec 2012
          • 3702
          Agreed, I read a car craft article a while back, they said average a manual eats about 18-20% of the power, while an auto eats upwards of 32-35% of power.
          Instagram @rebellionforge
          • ak-
            • 12422
            324x .82 = 265 at the crank. 18% loss.
            You did it backwards.
            He was 324 wheel.
            1991 325iS turbo
            • P Arkus
              • Dec 2012
              • 325
              He was 324 wheel.
              ^^^This. Using your formula of 18%, it should be 324 x 1.18 = 382 Crank HP
              Originally posted by 36brua
              Isn't that what these forums are all about making stuff easier... OO no never mind this is r3v...
              Patryk:up:
              Instagram: @parkus08
              91 BMW 325is ///M-Tech II
              08 VW .:R32
              04 Audi A4 Avant 1.8TQ
              • Cabriolet
                • 9620
                Originally posted by P Arkus
                ^^^This. Using your formula of 18%, it should be 324 x 1.22 = 395 Crank HP
                Fixed your math issue.
                It's a ~400hp engine
                Much wow
                I hate 4 doors
                • ak-
                  • 12422
                  What's his math issue? 18% vs 22%? lol
                  1991 325iS turbo
                  • VinniE30
                    • 2113
                    I've read it's around 15% for manual and around 20% for auto.(autos are more variable though since newer ones are more efficient.
                    I would say 15% for a rear wheel drive manual BMW.
                    Lets take the e36 m3 for example.
                    They usually dyno 200-210WHP bone stock. (dynojet)
                    They are rated at 240HP by BMW.(CHP)
                    240 - 15% drivetrain loss = 205 WHP so the 15% works out perfectly for that example.
                    edit:
                    OP, using 15% you would have 324 x 1.15 = 372.6 crank HP.
                    Also, you have to consider that different dynos typically read higher and lower than others, some are at shops to be used for tuning only, not for bragging rights, so they don't change it from the factory settings which may be conservative. So I would ask the place that it got dyno'd at (or the dyno manufacturer if they don't know) because they would know how their reading correlate to crank HP better than anyone.
                    Zinno '89 <24v swap in progress>
                    • Cabriolet
                      • 9620
                      na dude. bad math is bad. 1.22 is 18% (1/(1-.18)) = 1.2195
                      Much wow
                      I hate 4 doors
                      • ja burna
                        • Jun 2005
                        • 358
                        yeah figures were using a Mustang dyno.. so I don't know if they read lower or higher
                        • VinniE30
                          • 2113
                          They read lower than dynojet with the factory settings, but sometimes shops add in a correction factor to make customers happy with higher numbers, but that can be done on any dyno I believe.
                          Look at this article on dynos and how much higher/lower different manufacturers' dynos can be.
                          In this chassis dyno guide HOT ROD answers some frequently asked questions about dyno testing including comparing types of dynamometers and explaining what factors can impact your results - Hot Rod Magazine
                          Also see this thread: http://forums.bimmerforums.com/forum....php?t=1696183
                          And if comparing to a reading done on a different day or different place you have to consider how factors like temperature and altitude affect output.
                            • 34847
                            forget about calculating crank HP from a wheel dyno. it's totally pointless. not only does it change with ambient conditions, it changes with dynos, and the % is not linear - it changes for the same drivetrain based on how much power you put into it.
                            adding a magic 20% number, guessed from something you read on the internet (or pulled out of your ass, usually), to a wheel dyno result so you can brag about your mad HPs is one of the lamest bench racing excersizes there is. Chassis dynos are a tool used to tune an engine. That's all. The only comparisons should be cars done on the same dyno in the same conditions.
                            • LJ851
                              • 7919
                              Fixed my math issue, and nando is correct. Too many variables to make the calc anything but a wild ass guess.
                              Lorin
