What tool/tools am I missing?
  • bmw325csi
    • May 2007
    • 4045
    Any one know what tools I am missing? Specifically next to screw driver.
    harry/harout
  • flyboyx
    • 8371
    is this out of an e38 or e39?
    Gigitty Gigitty!!!!
    • Pl3wA
      • 1589
      if i recall, mine was missing a vibrator. yours might be too
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Paging Japandrew73.
        • bmw325csi
          • May 2007
          • 4045
          e34.
          Oh my vibrator is in my nightstand. It has no business in my trunk.
          harry/harout
          • Fusion
            • Nov 2009
            • 3659
            Iirc, it's always blank.
            • long tall eta
              • Jul 2010
              • 1536
              not always blank. only blank in e30's. my e28 had that piece. on e30's we just insert the hex tool to manually crank our windows down but on the e28's, you need to insert that piece, then if i remember right, you use the hex tool to expand that piece, it locks itself in, then the spark plug wrench fits over it and you slide anothe piece through the cross drilled hole and crank down useing a sort of t wrench set up.
              • Pl3wA
                • 1589
                We were referring to trunk as butt right? That would make everything better
                • bmw325csi
                  • May 2007
                  • 4045
                  Yea I tried that but it doesn't stay. I have the hex window tool in the spark plug tool.
                  harry/harout
                  • dannyg
                    • Mar 2007
                    • 1553
                    Paging Japandrew73.
                    1993 325ic Schwarz/Natur
                    1991 318is Black/Black - Slicktop - Project s52
                    1989 Alpine White/Black M3 S52
                    1988 Henna/Pearl M3 <3
                    • JinormusJ
                      • 6887
                      Why chew gotta steal mah swag mang?!
                      • long tall eta
                        • Jul 2010
                        • 1536
                        on my 86 es, i just insert the hex crank in the female slot in the door and crank it down. in the e28 u need to insert that piece that's missing from the e30 kits, take the straight hex key, insert in fitting, crank to lock on, then fit plug wrench over fitting, insert rod through cross drilled hole and turn down. if that makes sense
