E30 M40 to E36 M42
    E30 M40 to E36 M42
    Hi guys!
    I just want to swap my M40 to M42. I want to take the engine from an E36 because E30 IS is rare here. I only know that I have to put the oil pan from the M40 to the M42 and that I will need the E30 IS engine mounting brackets. Transmission is the same. I need a little help in the wiring. If i know well the E30 has different pin layout (and maybe connectors?). So what should I do with the wiring harness? Do I need the E36 wiring or the E30 wiring can be modified to get all the things work?
    Thanks;)
    FYI, the engine from the E36 318is, 318ti, and Z3 1.9 was the M44B19. When you're doing your search, it will help if you look for "M44."
    1987 Mercedes 190E 2.3-16: Vintage Racer
    2010 BMW (E90) 335xi sedan: Grocery Getter
      Yes you're right, but if I know well the Coupé has the M42 Engine till 1994.
        Tomy, they don't have m40s overseas. Lucky bastards :P
        '84 e30 320i m20b20 zobelbraun metallic
          M44 is a pile of shit.
          M44 came about for OBDII circa 1996.
          M42 was up until 1995.
            M40 and M42 use the same ECU, so I don't think it will be that hard to convert the 2. If the E36 motor has the flat accesories belt, you may have a few small difficulties- I know the E30 front accesories will not fit in the e36, they rub on a frame piece.- just use the front of the M40 motor and that will be solved.
            I would alsos just run the M40 wiring harness- should be totally doable with minimal changes to a couple connectors. maybe the M40 engine brackets will also work on the M42.
              this right?
                check www.e30zone.net, it has a lot more info about the m40 as well as the swap you mentioned
