Broke my hood cable
  • vert_this
    • Feb 2012
    • 395
    A long screw driver inserted and rotated from the from of the car will pop the hood with or without a cable. So if you don't want to repair it simply carry a long flat tip screwdriver to pop as needed.
    When I do this repair I just take some duct tape and use the old cable to fish the new cable. You duct tape tightly one cable BUTTED up against the other cable at the very end of the old one then pull the old one through to the other side, until you get to the new one. discard ductape
    • Rockwool2117
      • Jan 2013
      • 143
      the cable being pulled releases the latch, the the tension of it being pushed back to resting position locks it into place???
      The day I bought my e30, was the day I became sophisticated and classy as fuck.
      • vert_this
        • Feb 2012
        • 395
        The spring on the lock pulls the lock back into position. The cable is just that nothing more than a cable.
        • AndrewBird
          The Mad Scientist
          • 11898
          If the cable is stuck in the open position, the hood won't latch. A dirty latch will put excess load on the cable, potentially causing it to break, then stick open do to grime and grout holding it open. When you put the new cable in, pull the latch out and clean it.
          • Rockwool2117
            • Jan 2013
            • 143
            thank you for answering my question. I checked out the shirts, take my money
