#^*+}% Alternator belt..
  • E30nub1
    • 402
    This isn't an issue more of a rant......
    What started out as a grand evening.. Went totally sour..when my alternator belt decided to shit itself......son of a mother fuckin bitch.....perhaps what they say is true....nothing good happens after 12am...if you aren't where you are going b4 then just stay home.....
    sigpic"God made cars to be RWD and standard"
  • Nick_S
    • Apr 2011
    • 3658
    That sucks...but they're like $10, it could always be worse.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • roguetoaster
      Biggus Tippus
      • 7830
      If this ever happens again you can use your shoelaces with a number of knots in them as a substitute belt. Or if you like your laces just get a bunch of HD zip ties and keep them in the trunk, you never know when they will come in handy. After all, some charge is better than none. Enjoy your future 12AM+ outings!
      • Xat1cZ
        • 2020
        Did you compliment it on what it was wearing, take it out for dinner etc.? if not, this might be the problem leading to your belt finally snapping and leaving you. Pay attention to it, make sure the belt know that it is appreciated, and check if it needs something daily, and you'll be fine with your next belt.
        • E30nub1
          • 402
          With all this being said my adjuster bracket.. Won't adjust all the way down as to move the alternator down far enough to slide the new belt on.. What am I missing??? 13mm nut is loosened so as to wrench the 19mm but on the front... Suggestions??
          It keeps slipping teeth and eventually strips the teeth..
          • Todd Black 88
            • Oct 2007
            • 3449
            Lol, back in university days this happened to me. I was on a date and asked her if I could use her nylons. She laughed, went to the back of the car and took them off, out of sight. Gave them to me and I used them. Got us back to campus. Turns out, that's all she was wearing under that skirt;)
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • Nick_S
              • Apr 2011
              • 3658
              Loosen the one on the mount. If it's tight it won't let the alternator pivot.
              05 Honda Pilot
              24V swap thread
              • dougie30
                • Apr 2012
                • 1708
                Is it just me or does the bolt the loosens and tightens the alt ALWAYS strip out.. Its happened to me 3 different times
                M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  When I am at the junkyard I always try to "liberate" failure prone hardware . You should too.
                  • blunttech
                    • 12850
                    The large bolt head on front isnt for tightening . its for adjusting. Use the nut on the backside and you wont rip the teeth out
                    sales@blunttech.com
                    www.blunttech.com
                    Like us on Facebook
                    • e30vert
                      • Jan 2005
                      • 1789
                      Ive got an extra belt that I zip tie down together so that it takes up less space which I just leave in the trunk. Have never needed it yet cause I always change my belts regularly. For 8 bucks or so from BMA why not have a spare or two?
                        If the parts are good, stripping the bracket or the teeth of the adjuster nut is caused by failing to loosen the pivot bolt at the bottom of the alternator.
                        • E30nub1
                          • 402
                          ??at the bottom??? I thought there was just the nut on the back...and the. Big ass nut on the front to adjust.
                          Question is that the elbow piece that is also connected to the ps pump?
