Will halfshafts from an ABS car fit a non-ABS car?
  • Ben Carufel
    • Jun 2004
    • 5248
    I.E. will the halfshafts from the '88 325is I parted fit an '85 325e?
  • Digitalwave
    is a poseur
    • 6302
    The difference would be in the hubs so I am 95% sure they would work.
    RISING EDGE
    • Ben Carufel
      • Jun 2004
      • 5248
      ETK lists two separate part numbers for ABS and NON ABS cars.
      That's why I wonder...
      • DaN
        • 1265
        One has the ABS rings on it, so as long as it has enough clearance, I guess it would work.
        • Ben Carufel
          • Jun 2004
          • 5248
          Hrm...anyone done this?
          • turnofftheradio
            • Apr 2005
            • 448
            my bet would be yes, providing you change the backing plates, as with the front
            • Joe318is
              • Sep 2005
              • 6451
              May i suggest replacing you work out old OE subframe bushings with IR's newly redesigned Poly urethane bushings? They only that 5 minutes to put in, and let me tell you have wonderful they are! Yes, replace those 15 year old bushings for pennys on the dollar! How you may ask? With this revolutionary design youll never second guess yourself again! :roll:
              Originally posted by vlad
              • Ben Carufel
                • Jun 2004
                • 5248
                Sorry?
                • turnofftheradio
                  • Apr 2005
                  • 448
                  Originally posted by Ben Carufel
                  Sorry?
                  x2?
                  • mikeedler
                    • 6707
                    yes, they will fit.
                    my M3 has one non-ABS shaft on it right now, cause one exploded last year. and no, the ring from a ABS shaft will not stay on a non-ABS shaft.
                    hope this helps.
                    • Joe318is
                      • Sep 2005
                      • 6451
                      My name is JHOMO on Roadfly
                      • Rigmaster
                        • 3464
                        Originally posted by mikeedler
                        yes, they will fit.
                        hope this helps.
                        I disagree.
                        He asked if the ABS shafts would fit on a non-abs car. In my experience, they do not fit. I tried to put an ABS halfshaft on an '84 or '85 325e that did not come with ABS, and the hub got bound up in the trailing arm- not sure but I believe it was the ABS toothed ring- so if you can cut/chisel the ring off, it will probably work.
                        Bret.
