Don't like wheel spacers?
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5616
    While machining some wheel hubs today at work, I was thinking about designing some e30 wheel hubs that would be 5mm, 10mm,.. ect thicker than the OEM ones. Using this wheel hub would be more rigid than the traditional spacers.
    Just wanted to get some feedback and opinions
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    also make them 5 lug while you are at it.
    5x120, center bore 72.5mm
    k thnx
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Will you be making custom brake rotors too?
      • lambo
        Captain Scene Points
        • 10953
        While you're at it, make some 5 lug hubs ;)
        Edit: fuck you 10 Toes
        • 10Toes
          • Jan 2008
          • 61222
          Leave all your fancy measurements and thinking out of this.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            I figured you would have been the one to come up with that.
            • Stephen
              Шлем ишака
              • 10774
              you should make them angled 2 for sweet camber
              • Vivek
                attention whore/retard/bitch
                • 6167
                Nah dude just cut the caliper brackets and shave the inside of the rotors. Should work fine and be perfectly safe
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • lolcantturn
                  • 4588
                  why hasn't anyone made 5 lug hubs yet
                  why
                  Originally posted by TSI
                  OEM+
                  • 10Toes
                    • Jan 2008
                    • 61222
                    why
                    I know of at least two that do already,one in the UK and one in Germany.
                    • Danny
                      • 14216
                      There's a guy on here doing it as well.
                      • 10Toes
                        • Jan 2008
                        • 61222
                        I just saw those
                        • pandaboo911
                          • 2070
                          why has nobody done it? because it ain't cheap to machine the tolerances required for the bearing surface
                          • MrBurgundy
                            R3V Degenerate
                            • Mar 2012
                            • 5616
                            Well, of course I'd make 5 lugs.
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5616
                              and there will be a shoulder on the new hub for the rotor to sit in its original position. duh
