Ran my 325e on the dyno today!
  • DaN
    • 1265
    I go to school at UTI, and they have a couple dynos available.
    Made 4 pulls with my 85 325e. Stock hp at the crank is 121, 170 torque.
    Mileage: 210,279
    Ambient Temp: 65 degrees F.
    1) Max power 116.3, Max Torque 150.8 in 3rd gear.
    2) Max power 118.9, Max Torque 160.3 in 3rd.
    3) Max power 118.4, Max torque 158.6 in 3rd.
    4) Max power 114.6, Max torque 154.7 in 4rth.
    I'm pretty happy with it, I estimated 115 hp, 150 torque, and was pretty damn close. :woowoo:
    Mods:Shaved head (.020") Bav auto lowering springs, bilstein touring front struts, muffler man 2 1/4" exhaust with high flow cat and Flowmaster delta flow muffler, ebay knockoff ecu chip, shortened shifter with acura tl perforated leather knob, cone filter, bigger 325i throttle body, Bav auto 8mm perf. wires, bottle cap 14s painted black, chrome window trim painted black , lol
  • Jonathan M3
    • 1837
    Great numbers, especially with the mileage. :up:
    Do you have any printouts of the graphs??
    Was it a dynojet that you used, or another type of dyno??
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
    • DaN
      • 1265
      I have a printout, but I don't have a scanner to post it. You'll have to trust me, lol.
      I'm pretty sure that it was a dynojet, don't know the model. For some reason it doesn't say on the printout.
      I'll see if I can find out tomorrow.
      • Jonathan M3
        • 1837
        I trust you ;) , I'd just like to see what your curves look like and what rpms you're making your peak power at thats all.
        • LikeCDoos
          • Jan 2004
          • 2522
          wow those are real good numbers for how old the car is, good work
          • Digitalwave
            is a poseur
            • 6299
            Not bad, not bad.
            RISING EDGE
            • Nick325is
              • 1409
              Not bad at all for the mileage. Any plans in the future for your car?
              Nick
              • C ///M
                • 1040
                Damn, you're running a super low percentage of driveline loss. As everybody said...awesome numbers for mileage. You gotta find out what dyno you were using.
                332iS R.I.P.
                • Fred
                  • 659
                  Great numbers! I pulled something like 114 with my old eta.
                  Fred
                  '86 325 2.8i stroker - Arctic Blue
                  '11 328i Sports Wagon - LeMans Blue
                  Strictly Eta
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    Seems kinda low if you're running higher compression and a chip. The chip's usually good for 20+ hp on an eta.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • C ///M
                      • 1040
                      Oh, my bad... I didn't even read the list of mods. I thought you meant stock...so that's why I was confused...anyway.. still decent numbers for mileage.
                      332iS R.I.P.
                      • DaN
                        • 1265
                        Nick
                        In about a year or so I should be working as a BMW technician, so I will disassemble my eta and reassemble it as a track car. Ill be able to afford it. I was thinking about 2.7i, with either a built high reving motor, or a turbo 2.7i.
                        Hopefully I can pick up an e36, or e46 m3. Or perhaps and e39 m5 as a daily driver..
                        -Charlie
                        Yea, I figured the chip claims were exagerated, or those numbers are at the crank?
                        If you figure in a 20% drivetrain loss, its 192 ft/lbs, and 142hp at the crank.
                        Thats 22 ft/lbs and 21hp increase.
                        I suppose I should be making more power than that with an exhaust, higher compression, and TB. I guess the poorly flowing cyl head is holding this beast back, lol.
                        • DaN
                          • 1265
                          Fred
                          Was it stock?
                          • Jordan
                            • 12916
                            20% driveline loss is way too high.
                            15% is more realistic.
                            https://mtechniqueabs.com/
                            • DaN
                              • 1265
                              alright,
                              Then 136 hp, and 184ft/lbs at the crank.
                              Still decent, but not great.
