215 tires + 300hp?
  • stanhayward
    • Mar 2013
    • 765
    215 tires + 300hp?
    Hey I didn't think this fit in any of the other discussions but I'm wondering about the correct tire sizes for a 300hp+ 325i. Right now my car only has about 200-205 hp from exhaust, intake, MAF & chip and is rolling on 205/50/16 Yokohama S Drives and all is well. My problem is is that I'm looking to make around 300hp from either an engine swap or FI. I have a 9 inch rear wheel so I could get a set of 215 S Drives, but will this be enough? Any help would be greatly appreciated, I don't have experience with high hp E30s... yet!
    1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
    1984 316 Coupe - The Base Model - Pain in the Ass
    1988 750iL - The Daily Driver
    ...And a couple others...
  • travish325
    • Jun 2012
    • 1151
    First off your car does not have 205hp.
    Second why have a 9 inch rim and a 215 tire? Stretched tires stance and high hp do not go together. With a 215 depending on your tire set up you will have some traction issues on launches and hard gear changes (which is going to be a problem on any higher hp e30)
    Id try to squeeze a bigger tire under it imho.
    • unevolved
      • Nov 2011
      • 714
      1991 318i SOLD
      2003 325i SOLD
      Racecars and stuff.
      • FredK
        • 14759
        You might want to use a stickier compound of tire. If you're driving this car on the street, then really it won't matter if you have a 205 or a 215mm wide tire.
        Getting 300 whp won't automatically make your car a widowmaker, but you'll have to dial back your right foot.
        • stanhayward
          • Mar 2013
          • 765
          Okay thanks. My bad on the horsepower, I thought a complete exhaust system with headers would make about 180 and then another 20 for the MAF and chip with intake. How far am I off by?
          • travish325
            • Jun 2012
            • 1151
            Originally posted by stanhayward
            okay thanks. My bad on the horsepower, i thought a complete exhaust system with headers would make about 180 and then another 20 for the maf and chip with intake. How far am i off by?
            25
            • stanhayward
              • Mar 2013
              • 765
              About this, I know that stretch and stance aren't the best for performance but I like the look and I'm not building a race car so I'm not worried about this. I like the occasional hard launch, though, so I don't want to spin tires through 3 gears is all. Thanks for the heads up, though!
              • stanhayward
                • Mar 2013
                • 765
                25
                That much? The engine just had everything replaced so should make about stock horsepower and then even just the MAF and chip are dyno proven by Miller Performance to add 16whp. Then I have the KAmotors carbon intake and Ireland Engineering Exhaust components. I find it hard to believe that all of that only added 12 horsepower at the crank.
                • travish325
                  • Jun 2012
                  • 1151
                  Its your car so do what you want.
                  I liked that look to but I tried running 500hp on a 225 tire stretched on 9.5in rims and all I did was eat tires and not go fast lol Im a little more on the performance side now so Im liking the fat tires and actually moving and not smoking my tires off.
                  • unevolved
                    • Nov 2011
                    • 714
                    Stock at the flywheel, maybe, then factor in 15-18% drivetrain losses and marketing fudging. If you don't believe him, throw it on a dyno and find out what you're ACTUALLY making.
                    1991 318i SOLD
                    2003 325i SOLD
                    Racecars and stuff.
                    • ak-
                      • 12422
                      The tire choice is fine.
                      Differential plays a good influential roll too.
                      1991 325iS turbo
                      • stanhayward
                        • Mar 2013
                        • 765
                        I also forgot to mention that I would install a 2.93 diff. Would this help? Obviously not for a launch, but for a 3rd gear pull?
                        • stanhayward
                          • Mar 2013
                          • 765
                          I was talking 200 at the flywheel
                          • travish325
                            • Jun 2012
                            • 1151
                            would help huge with a turbo set up
                            • fronton
                              • Oct 2009
                              • 1262
                              2.93 will help you keep traction because it decreases your acceleration ratio equally in all gears. 3rd gear pull is the same 20% slower than first gear would be vs 3.73. 215 is enough tire for 300hp at with 2.93 diff as long as they aren't all seasons. I would not drop to 2.93 though unless you are 95% highway miles and only care about MPG
