lucky. mine failed.
I passed CA smog
could either be too rich, or ignition system isn't working properly. Its basically HC is a measure of unburned fuel. Are you using larger injectors?Comment
Yeah, vacuum leak is a common cause. is your chip tuned for 19lb injectors? Does your exhaust smell like gas and you're getting bad mileage?Comment
yeah when it runs bad the exhaust does smell like gas. the thing is that when cold it can hardly idle and when i go to take off it will bog down and almost stall out. but if i keep the revs up for a couple mins it seems to run ok. but the idle will be surging a bit.Comment
