What's it worth?
    What's it worth?
    Hey People!
    Trying to get an idea of what my old car might be worth. Sold it to a friend about 5 yrs ago at 220K miles when I bought an e39 M5. At that time leak down and compression tests of m20 were perfect. He doesn't drive that hard and replaced the tranny with rebuilt(2nd gear synchro crunch) and a new clutch. Garage kept CA car for most of life, garage kept WA car for last 5. Small dent on drivers door at keyhole. Can be fixed prior to sale. Approx. 240k on car/od. gears gave out about a yr ago. I was third owner and did all mods and maint. Was like new when I originally purchased. I have nothing but BMW's for last 15 yrs and really miss this car!
    1989 Cirrus Blue 325i coupe/CA car for most of life
    Jim Conforti Chip
    Extrude Honed Intake Manifold
    Big Bore Throttle Body
    535iAFM/ Mustang Injectors/ RRFuel Pressure Regulator
    IE Ceramic Coated Shorty Headers/BB Stainless Exhaust
    3.73 LSD/Finned diff. cover
    Rebuilt 5 spd./ new clutch(maybe 5k miles ago)
    GroundControl coilover conversion w/SA Koni sport/ GC camber plates
    IE Adjustable swaybars w/reenforcments
    IE Sparco rep. front strut bar
    M3 aluminum control arms
    KMac urethane adjustable camber/toe trailing arm bushings
    Kosei K1 15in. wheels
    SS brake lines/ M3 master cyl.
    Ac/PS Delete
    I'm sure there is more that I can't remember. Best handling car I've ever had.
    10k+
      15k+
      1986 Plymouth Horizon. Base.
        8-9k
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
          $5k.
          But I am still living in a world where you could get $500 e30s and drive them home.
            with 250k and fat dent on it. i wouldnt pay more than 6000 for it.
            Much wow
            I hate 4 doors
              Originally posted by InuFaye View Post
              15k+
              The waffleswaffleswaffleswaffles?!
              I agree. Somewhere in the $5-$6k range is ok I guess.
              www.truegearhead.com
              - bad decisions & questionable cars
                Just needs some plastidip and a drift toy.
                  5-7k
                    God I love cirrusblau. I'd say 5k is a good buy, 6k would be a good sell.
                      Ok.....
                      Alright!
                      Thank you for the input guys. I will most likely take posession of the car and zero it out for my buddy. May keep it if I can work it(garage is full) but if not it will be up for sale when work is done. I will be having the dent fixed at a quality shop, replacing the "is" front lip that used to be there, and anything else that needs attention. I had already done all the bushings in the car and front bearings so I don't expect to have to do much. If I keep her the motor will be going in my wifes 87 Glacier Blue 325iC and a S5x swap will be in order.
                      Thank You!
                      Dan
                      2006 Z4MR
                      1988 535is
