Anyone with 3mm 5x120 Spacers in Orange County?
  • markseven
    • Sep 2006
    • 5327
    Can I please test-fit them?
    TIA,
    Mark
    I Timothy 2:1-2
  • FLG
    • Sep 2011
    • 3165
    Check with Ryan at motorsport hardware,
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • ak-
      • 12422
      Whenever I needed spacers under 5mm (twice and once for a friend) we just went to the local mom/pop tire shop and used those universal multi hole ones that are like $10 or less.
      No wobbles or nothing and they weren't even hubcentric.. Maybe because how small they were. Need any lugs btw?
      1991 325iS turbo
      • F34R
        sLaughter
        • 12376
        http://www.ebay.com/itm/2pc-3mm-5x12...c5107c&vxp=mtr
        I forget if you are e30 m3 lug swapped or e36. But these will do the trick both ways. Under 30.00 bucks SHIPPED from the USA.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • chance
          • Feb 2012
          • 671
          If you are just wanting to see where it puts your wheel, go buy a pack of washers. Dont drive with it like that obviously
          1991 335is in progress
          • markseven
            • Sep 2006
            • 5327
            I will keep this option in mind ;)
            Which lugs do you have?
            See below
            http://www.r3vlimited.com/board/member.php?u=9925
            Done and thank you.
            For some reason the E30 M3 (maybe just mine) is sensitive to spacers. I have 5mm (74.5 BC) at the moment, with Turner's hub extenders, and I have a slight shimmy at the steering wheel.
            No shimmy without the spacers.
            I want to see if 3mm eliminate the shimmy.
            Maybe I should see if someone has known good 5mm's?
            I Timothy 2:1-2
