I know wet sanding is a touchy subject especially for the novice detailer. Basically, if you don't have a tool that measures paint depth, don't do it.
That being said, I don't think my case is too dramatic. The paint on my E34 shines, but there's a problem. It has white overspray from someone spray painting something in the same garage it was in. The clay bar took most of it off, which leads me to believe it's not too bad. However, the rest I believe will need to be wet sanded.
I'm thinking 2000 grit wet sand would be safe and wouldn't be too risky going through the paint?
This is at it's worst on the hood, didn't clay this part. At the top of the picture you can kind of see the masking tape line where it was clayed and the hood shines pretty well.
