A/c broke in the rain this morning.
  • bowtie2bimmer
    • 830
    I live in NE Florida and thus morning we are being visited by tropical storm Andrea. Well about 2 minutes into my morning commute my a/c and fan just died. I went to turn it up to setting 3 and as soon as I did, the fan died and the lights for the a/c and recirculation went out. Fantastic. And of course I drive a vert, and my roof hasn't had a leak unless it was a down pour. Well sitting in traffic in a tropical storm made it leak all over my lap.... Double fantastic. So, needless to say, awesome commute this morning.
    What do you guys think the a/c and fan problem is?
    Sent from my DROID RAZR using Tapatalk 4 Beta
    1987 BMW 325ic - Emma
  • Vtec?lol
    • Dec 2009
    • 3278
    blower motor blew your fuse. Bad resistor
    • mpower
      • Mar 2005
      • 62
      Here's a start
      • bowtie2bimmer
        • 830
        I was thinking the resistor. I looked at the fuses under the hood and they all seemed to be OK. Are the resistors easy to find locally?
        • mpower
          • Mar 2005
          • 62
          Call some autoparts stores, otherwise online sources or the dealer.
          • bowtie2bimmer
            • 830
            I will, just stuck at work till 430. Blows...
            Well actually it doesn't, that's the problem lol
            • mpower
              • Mar 2005
              • 62
              Just mount this in your car. ;)
              • bowtie2bimmer
                • 830
                E30... Africa edition
                Sent from my DROID RAZR using Tapatalk 2
                • mpower
                  • Mar 2005
                  • 62
                  E30 Serengeti Super Sport Edition.
                  Zebra stripes optional.
                  • Nick_S
                    • Apr 2011
                    • 3655
                    Hit it with a hammer till it works again.
                    91 318is M50 swapped
                    05 Honda Pilot
                    24V swap thread
                      It sounds like fuse 20 has blown.
                      • bowtie2bimmer
                        • 830
                        Just went on break and checked the #20 fuse. Sure enough it was blown. Stole #28 since they since they are the same amp. My a/c switch lights came. I tried running my my fan through the speed 1/2/3 got nothing. When Iput it on 4, blew the fuse.
                        My thought is bad resistor in blower motor causing to overload the fuse. Of ocurse I could be wrong. Thoughts?
                          The resistor only affects the first three speeds. It is bypassed for speed 4. While the resistor could be bad, the fuse blowing in speed 4 suggests a shorted blower motor or one that is mechanically jammed.
                          • Click
                            • 637
                            Sounds like there might be a short in the blower motor which has burned out resistors 1,2, and 3 and since 4 is just an open switch it blows the main fuse.
                            ส็็็็็็็็็็็็็็็็็็็็็็็็็
                            I need you to exfoliate my ballsack
                            Build Thread?
                            • Timmyboy
                              • Jan 2013
                              • 99
                              i feel your pain, we have the exact same car and the same shit happens to me. I just dont use the A/C unless im cruising at a steady speed cause its causes the idle to rev high with the clutch in.
