inexpensive welder..
    • 34847
    I keep seeing welders everywhere for under $100. There are several projects I'll be working on soon that require welding (I am a capable welder, I just hate having to borrow somebody else's all the time). I've been thinking of picking up a wal*mart special for shits and giggles. anyone have experience with one before I waste my money?
  • BahnE30
    • 1050
    if your only welding thinner steel and in little amounts you should be fine.... i had a walmart special and i was making a trailer with it, ended up burning the fucker out after about 5 hours..... so i bought an expensive one 6 years ago and the only thing i've done to it is put wire in it and clean the tip out..... Lincolin MIG for teh win
    • nickmp0wer
      • 1427
      yeah i have a lincoln something, the first time i will be using it will be this weekend, but it seems to be very good quality. Is intershield welding any good? or should i get gas?
      • nkell09
        • Jan 2004
        • 575
        I have a Lincoln SP135, I've always had it running gas. Good for lighter gauge metal and it generates less slag when compared to fluxcore. I typically use it for bodywork, so I couldn't speak for the lower gauge metals. If I recall, fluxcore is better suited for lower gauges.
          • 34847
          I want it mostly for suspension stuff (trailing arm, subframe, struts etc) - nothing terribly heavy duty. doesn't have to look pretty, just has to be strong. looks like i'll be okay with a cheaper one (I can get a nicer one when I have my own house).
          • 2002maniac
            • 4260
            Fluxcore is ONLY good if you are welding outside where wind will blow away your purge gas. Get a 220v welder with Gas and you will be much happier.
              • 34847
              heh, well I'm not exactly going to be welding in my living room.. I don't have a 220v outlet here anyway.
              • AndrewBird
                The Mad Scientist
                • 11898
                Lincoln make a great product. We have a small 110V fluxcore welder that will weld up to 1/4 I think. It works pretty well, but it is sometimes hard to get a clean looking weld. Gas setups look so much cleaner and IMO, are easier to weld with.
                Lincoln makes 2 different 110V MIG (gas) welders for a couple hundred bucks. Hobart also makes a couple smaller 110v welders. Both are great companies. Just buy the best that you can afford.
                • Jordan
                  • 12916
                  In the near future I'm definately going to be picking up a wire feed MIG with a small Argon tank. I picked it up quick at work and I really do some beautiful beads these days with it.
                  https://mtechniqueabs.com/
                  • Jand3rson
                    • 37587
                    Welding is an art, so much more than people think. I have mad respect for people that can do it well, and I look forward to learning to do it.
                    • mrsleeve
                      • Mar 2005
                      • 16390
                      whats with all the lincoln's, Get with the program Millers are the best.
                      But relly either or is fine, get a samll 220v gas shielded. Flux core sucks ass, you wont be sorry. Just save a little bit longer and get a good one it will last much longer and preform better than 145 dollar farm supply special.
                      Just my 2 cents though
                      Originally posted by Fusion
                      William Pitt-
                      • 2002maniac
                        • 4260
                        I have been extremely happy with my 220v Millermatic 185.
                        If you dont think you need gas or 220 (and you really do) dont selll yourself short on a cheap crappy welder. You will never have any sucess at all with a piece of garbage. I wouldnt consider anything but a Hobart, Miller, or Lincoln.
                        • motorprestige
                          • Oct 2004
                          • 788
                          my dad has been a welder for 30 years. I need to learn how.
                          "Having won more road races than any other model in history, the E30 M3 is considered by many to be the world's most successful road race car." - Simply put, E30s kick ass.
                          • nkell09
                            • Jan 2004
                            • 575
                            When I purchased my lincoln, I priced out comparable Hobart and Miller models. The lincoln had some of the better prices in the list. It also included fully variable line speed / amp control (one of the few differences).
                            It just suited best for the buck and quality. I have had it for 4 years now and have am on my fourth gas tank....
                            • FJ40
                              • Mar 2004
                              • 241
                              At this point esab, miller/hobart, and lincoln are all really great welders. I wouldn't suggest a cheapo, especially for suspension work, and as was already mentioned, if you think you will be doing much 1/4+ get a 220V rig.
                              chase
